Results 111 to 120 of 1510
- Feb 2005
- 12
July 27th, 2007 10:15 AM #111looking for comfort tires
long lasting
reliable
195/55/15
any recommendations?
where do i find the cheapest prices?
Tsikot Member Rank 4
- Jun 2006
- 2,605
August 6th, 2007 09:18 PM #112
August 7th, 2007 11:19 AM #113
Which is better guys (235/60 R16)... I'm already sold at the Turanzas although am intrigued by the low-resistance Michelins (but my preference is for a grippier tire especially on wet roads).
Michelin Energy MXV8 - P7,500+
Bridgestone Turanza ER60 - P5,200+
Bridgestone Dueler H/T 687 - P4,500
Thanks!
August 7th, 2007 12:18 PM #114
Comfort tires in 195/55-15? Try C-Drives or Turanza GR80s, but they ain't cheap.
225 versus 215/70-15, it's only a difference of about half an inch or less in height... should be more comfortable, too, on the smaller tires (slightly), but it'll make your odometer run fast.
The MXV8s are supposed to be good tires, but they're really expensive. We just got the Michelin Synchrones for the Crosswind... awesome tires, but I don't know if they have sizes for the RAV4.
Turanza ER60... decent lang... prefer the GR80, as it's way better, but I think they're also expensive.
August 7th, 2007 12:22 PM #115
oops... typo... turanza er30 not er60...
oem tires daw ng miata & e46...Last edited by mazdamazda; August 7th, 2007 at 12:28 PM.
August 7th, 2007 02:06 PM #116
Kunting info lang po ito tungkol sa tire po:
e.g. ____________ P195/55R16 85H ____________
ang P ____Passenger vehicle tires
..... 195 __Width of tire na 195 mm.
..... 55 ___Height ng side wall 55% of the width(195) so, 107mm.
..... R ____Radial
..... 16 ___size in inches ng wheel.
..... 85 ___the load index na equiv. 515kg/wheel.
..... H ____speed index at ibig sabihin ay 210km/h max speed.
anyway, ang pinaka importante na dapat malaman ay yung manufacturing date !!!!
e.g_________ ( 2104 ) _________(may have asterisk)
ibig sabihin nito ang date of manufacture ay ika 21st weeks of year 2004
kaya importante ang manufacturing date na malaman bago bilhin ang gulong dahil 4 years lang ang validity period ng tires and after that tires may burst whilst in use.
sa example DOM na 2104 dapat huwag ng gamitin ito next year 2008 mga bandang Mayo.
kadalasan magulat ka bakit "mura" iyun pala eh maexpire na next year o di kaya expired na talaga.
August 7th, 2007 02:18 PM #117
sa japan nga pala eh minsan makita mo iba ang label___195/620R16___ kasi kinumpyut na yung diam na 16in. so 406mm plus 107x2 so 620. iba style doon.
August 7th, 2007 02:42 PM #118
bigyan emphasis ko lang yung manufacturing date sa tires ha.. (DOM Date Of Manufacture.)
apat na digits lang yun at ang huling two digits ay di dapat lalagpas sa current year(e.i. 07) madali lang makita yun.
as i've mentioned earlier eh importante ito dahil nga most accident happened ay dahil sa pag burst ng tire and tire validity which is only 4 years from manufacturing date is very important to be verified before buying.
kaya check nyo rin gamit nyong gulong now!!..kung ang DOM ay 2703 or lower exprired na yan!!
na banggit na pala ito ni odiong929 last apr29 sa page 5..ayon at may site address pa..just back check..marami pang importante bagay sa tires ang dapat na alamin din gaya ng A or AA ano yun? see...
- Jun 2006
- 2,605
August 7th, 2007 06:49 PM #119
August 7th, 2007 08:09 PM #120
Whenever you change width, you change height.
As dbuzz pointed out (and which I'm already familiar with, having changed tire sizes so often my head spins), 225/70R15 means 225mm times 70% = your sidewall height. Going down to 215/70, you lose 7mm of sidewall height... calculated into your tire diameter, you run about 2% slower on the road against your odometer (which will read faster).
With your current size (215/65R15), refer to http://miata.net/garage/tirecalc.html ... your odometer is running 5% faster than before. Some dealerships supposedly can adjust your odo, but I don't know if that'll work with your current vehicle.
Did some independent research and decided to go with the white pearl crystal.... para maiba naman. ...
