Results 81 to 90 of 1510
April 25th, 2007 01:34 PM #81
thanks for the reply, niky. now i don't have to worry on the camber and alignment if i'll change my stock tires to 215/45R17 combo. hopefully makakuha ako ng good deal for bridgestone potenza. any idea how much is the price of potenza 215/45R17 ngayon? i got a quote from the other forum nasa 6.5k raw ito ngayon.
April 25th, 2007 02:10 PM #82
Sounds about right. You might be quoted over 7k at some places, so you'll have to shop around a bit.
- Apr 2007
- 9
- Mar 2007
- 224
April 28th, 2007 01:44 PM #85
Nakuha ko ay 225/55/17 sa Tuazon, Cubao. Mag-scout ka lang. Medyo nahirap lang akong maghanap ng ganitong specs kasi out of stock. Pero worth it naman ang paghintay. Quiet ito at good grip.
Re. replacing your tires, I don't think it need to have a camber and alignment.
Bago pa kasi auto mo. Wheel balancing ang dapat if you'll replace it.
April 28th, 2007 01:48 PM #86
- Aug 2006
- 70
April 28th, 2007 11:09 PM #87Guys, since we are now talking of tire brands, does manufacturing date have something to do with their performance as experienced by different users?
April 28th, 2007 11:43 PM #88
You shouldn't buy tires past a certain age, as they have a definite shelf-life.
I'm not sure what that shelf-life is, though... I'd wager about three years in our conditions (the heat, the alternating dryness and humidity... etcetera).
- Aug 2006
- 70
April 29th, 2007 10:57 PM #89I got this from our office mail.
TIRES.
Vehicle tires have a 4-year validity period from their Date of Manufacture (DOM). Thereafter, the tire expires and may burst whilst in use. How to find out whether your tire has expired? Check for a stamp like this: (*2603*) There is an asterisk in the beginning and at the end of this serial number. The first to numbers 2 6 will tell which week of the year has this been manufactured.
NB: One year has 52 weeks. The last two digits represent the year of make. Therefore *2603* shows that the said tire is manufactured on the 26th week of 2003. *2699* this shows that the tire is made on the 26th week of 1999.
Check all your tires for safety purposes. Do not use expired tires, They are likely to burst (Specially when running in hot weather) because the rubber component may have hardened and cracked. (see sample picture)
April 30th, 2007 10:32 AM #90
thanks sir, hindi na nga siguro kailangan pa adjust camber and alignment. pero pa check ko narin kasi libre naman daw yung check up dun sa pinagtanungan ko na tire auto supply sa pasay. libre din nila yung nitro pag dun sa kanila kukuha ng rim and tire. i'll get the potenza na kasi dami nagsasabi na maganda nga grip nito at tahimik.
nga pala sir, ganda ng avatar mo ah. yan yung kukunin ko na rim (velbret)
