Results 71 to 80 of 1510
April 6th, 2007 02:43 AM #71
^ meron din ako nakita dun sa malapit sa domestic airport. yung pagbaba ng fly over from edsa.
Tsikot Member Rank 4
- Jun 2006
- 2,605
April 6th, 2007 09:52 AM #72
April 12th, 2007 02:11 AM #74
ok ba ang hankook tires? napansin ko lang na kahit pudpud na cya, hindi cya nagka-crack. yung goodyear at ridgestone ko, kahit makapal pa eh marami nang cracks.
April 24th, 2007 05:21 PM #75
i'm planning to change my stock tires to 215/45R17. which would you recommend bridgestone potenza III or dunlop lemans 702? why?
April 24th, 2007 06:15 PM #76
I'll go for Bridgestone Potenza G3. I bought last week and looks ok and quiet.
Mas durable daw. I've been using BS tires for more than 10 years. Wala pa naman ako ne-experience na problem. Siguro ingat lang sa mga lubak...
- Dec 2006
- 5
April 24th, 2007 08:13 PM #77question po, ano po ba ang tamang tire size para sa lite ace? yung malapad po ba like 185/70/R13 or yung medyo makitid lang like 165/80/R13? e ang tire pressure po ng mga tire sizes na yan, ano po ang tama? meron po bang tires with that size na mura at maganda ang quality na nasa range ng 1.2K~1.5K per piece?
sana po matulungan nyo ako.
salamat.
April 25th, 2007 09:36 AM #78
i think i'll go for bridgestone potenza narin siguro. marami rami narin ako nabasa na magandang review nito. anong size yung nabili mo, sir at saan mo nabili? i'm planning to change my rims and tires next month.
nga pala another question, if magpapalit from stock tires (altis) to 215/45R17 do i need to have a camber and alignment check pa? mga 1 month old palang po yung car.
April 25th, 2007 09:53 AM #79
I'm currently running Hankook Ventus Sport K104's (245/40/20) on my Outlander, I bought them after reading good reviews at Tirerack.com, low road noise reliability and very good wet/dry traction.
On my w201 I have Indonesian made Tornado Alphas (215/40/R17), they're really good tires if you can find it there in the Phils.Last edited by the josh; April 25th, 2007 at 09:57 AM.
April 25th, 2007 11:21 AM #80
Mahirap sagutin yun... mahal na rin ang tires sa size na yun. If you want truck-like longevity, you can go for Goodyear Wrangler Sports, but they're expensive. I got 165 or 175 Michelin XM1s for my pickup at 2.5k each. Relatively expensive for car tires, but they're very very quiet. Not so good under braking, but they're meant to be fuel conserving tires, so you should drive them gently.
Pressure is whatever it says on the door sticker. But you should use 30-35 psi with modern tires, and a bit more if you're driving with a full-load of passengers.
You shouldn't need to. Lowering springs may change your camber (but the Altis' rear beam design should prevent excessive camber), tires won't.
Potenza Grid III's are nice tires. Very grippy yet relatively quiet.
