Results 971 to 980 of 1510
September 24th, 2013 11:00 AM #971
September 24th, 2013 11:23 AM #972
Positive vouch for Maxxis Victra 195/55R15
Bought more than a week ago. Very grippy even in wet roads. No floating feel even if speeding in wet roads.
We also use Maxxis Marauder for our Starex GRX. Almost same performance as the Michelin Agilis it replaced while costing a lot less.
- Sep 2010
- 19
October 27th, 2013 12:05 PM #975Also have Dunlop LM 703 215/55/17 in my Camry. Tires are ok but noisy, have a humming sound 50kph upwards especially on asphalt roads.
I thought the noise was because the tires were new, but they already ran 10K kilometers and are still noisy.
The tires sound like the engines of an airplane taking off when your inside the plane. Anyone else experience this?
October 27th, 2013 12:59 PM #976
^ I use LM703s on my Corolla (215/50R17) and there is tyre noise but i'm not much bothered by it (25,000kms already at this point). Perhaps its noticeable on your Camry if you came from Bridgestone tyres before as i usually found the Bridgestone tyres to be generally quiet (at least with the the Turanza line we used before). I'm running anywhere from 35psi to 37psi. Switched to nitrogen too, mainly so i don't have to air up too often. My tyre pressure has hardly changed in over a month.
- Sep 2010
- 19
December 28th, 2013 08:20 PM #978
About to change my 4 tires for the lancer next week, ano ba maganda based on your experience/s lately?
Currently using Toyo DRBs 195/55/15, it lasts 4 years and still okay but i will not risk it anymore.
DKC quoted me 3650 each for the same tire, proxes also at 3650, federal evo595 at 3550. Also considering kuhmo ecsta and bridgestone ecopia.
I might go for the DRBs as i had good experience in those rubbers, but i would welcome some other suggestions, kindly share if you have.
- Jan 2011
- 300
January 3rd, 2014 03:09 AM #979Meron na ba dito nakapag try ng Achilles kase mukhang promising yung brand either yung 2233 or ATR sport sana balak ko kung meron na 205/45/17 tsaka kung Ok kaya siya sa tag-ulan considering yung road condition ng Pinas?
January 3rd, 2014 09:38 AM #980
Or none of the above? We've had Ferraris and Lambos burn in SLEX and NLEX in the Philippines...
Hybrids and EV
