Results 801 to 810 of 1510
- Aug 2012
- 2
August 3rd, 2012 09:57 PM #801Feedback lang sana guys. Has anybody tried Toyo Proxes ST II? Our car (Isuzu Trooper) needs tire replacement and planning to purchase a Proxes ST II na size 265/70 r16. Here's a link ( PROXES ST II | Toyo Tires ) I know that Toyo Tire's is also a reliable brand. Im just having second thoughts of purchasing one because wala pa ako nakitang Proxes na tire na nakakabit sa mga suv with those tire specs. Ang kalimitan na nakikita ko yung mga pang low profile lang yung mga nakikita ko na naka combo sa mga 18's - 22's na mags but I never saw one with the 265/70 r16 na specs. Is it worth it versus common brands like Bridgestone, Dunlop, Yokohama etc. with regards to its handling, thread life and ride comfort? May naka try na ba sa inyo?
Also ok din ba sa Gladdie's Tire Supply sa Sta. Cruz Manila? Dun kasi ako nakakita.
Thanks in advance guys
August 4th, 2012 01:55 AM #802
August 5th, 2012 11:26 PM #803
Mga sir okey din po ba yung Maxxis Tires balak ko kasing magpalit from 185 to 195R14C. Ang price nya dito samin sa Bicol ay P3,600.00, GT P3,800.00 and Federal P3,100.00.
Thanks.
- Aug 2012
- 27
August 6th, 2012 10:05 AM #804Hi Guys, noob to the forum here, I would really appreciate your help in my query. I have a 2007 Innova G 2L with stock tires - Yokohama sha, although I dont know specifically which kind. a guy from a vulcanizing shop na nagbebenta din ng tires says that I need to change tires na daw dahil daw baka pumutok na yung tires ko, and because may leak na daw yung pin ng gulong ko. At that time, yung tinitingnan nilang gulong eh yung spare tire ko na wala pang 1 year ginagamit.
I asked na kung pwede palitan na lang yung pin and sabi nila mga 3500 din daw yun bili na lang daw ako ng bagong gulong. Feeling ko nakakagago yung style nila if ever they were trying to pull a fast one. I called our agent at toyota and sabi nya ang pagbasehan ko daw kung need na ng tire change ay yung tread ng gulong. I seldom take the car for long drives and use the car for city driving at about 2x a week lang. What do you guys think? Thank you
August 6th, 2012 11:24 AM #805
Get a second opinion from an established tire shop. Did i get this right? Pin??? The valve where you inflate the tires from? Chacnes are the vulcanizing shop is pulling your leg. I stopped going to those kanto vulcanizing shops and always have the store where i bought the tire from do the repair if possible.
- Jan 2008
- 172
August 6th, 2012 11:42 AM #806^yokohama aspec stock tires ng innova
the thing is, almost 5 years na din namin running ang gulong mo, check the date when was it manufactured. Like a life span but not exactly a life span, tire failures happen often after its 5th year (blow out, bukol, cuts), it happens also sa early life ng mga chipipay na tires.
have it check sa mga tire dealerships like minerva, tyre rack and other reputable shops.
- Aug 2012
- 15
- Jul 2008
- 935
August 7th, 2012 05:14 PM #808
August 7th, 2012 05:29 PM #809
August 7th, 2012 07:59 PM #810
Daming issue ng SU7:grin:
Xiaomi E-Car
