Results 651 to 660 of 1510
- Mar 2005
- 703
May 28th, 2011 01:47 AM #652Check if the model is current, I guess. If you've done your research, go for models/sizes that have reinforced sidewall tech.
Tsikot Member Rank 3
- Oct 2006
- 1,069
- Feb 2010
- 336
June 12th, 2011 11:04 PM #655already used Hankook for 3 years OEM tires when i bought my van then tried Goodyear HP AW w/c give me a head ache just recently...only 1 year when 2 front tire edges wears out interchange at the back same thing happened after a year, worst is tire began to show sign of woobling becoz of deformed shape (na-oblong yun RH front & rear) so i have to replaced all 4 after two years which i thought could reach at least 3 years like the previous one but i was wrong...now after thorough research and advices from the owners themselves i decided to buy Michelin Agilis w/c have a good feedback & reviews, i'm hoping it could last as i expected w/ proper maintenance of course >>>
- Feb 2010
- 336
June 14th, 2011 01:13 AM #657yes sir i will...cross my fingers on this brand otherwise switch mode again w/ other brands, hehehe
- Jun 2007
- 135
June 14th, 2011 01:54 PM #658Hi guys! Which one should I buy for My Altis, 195/60/15? I wanted Bridgestone GR-90 kaso mahal by almost 4k for getting 4 tires. Sayang din yun. So in praticak buyer mode, I might choose either of the 3 below.
For your kind comments please. Thank you!
Yokohama A.drive ---> I seem to not like the stripe layers on the sidewall.
Dunlop LM703
Dunlop Eco
June 20th, 2011 02:10 PM #659
June 21st, 2011 10:13 AM #660
Have no experience with the latest Dunlops LMs but the A-Drives worked quite well on our Sentra (and it has a high tread wear rating just as well). When i was choosing between the 195/60R15 Bridgestone Turanzas and Dunlop LM702s some years back, one reason i went for the Turanzas was that it had a noticeably thicker sidewall when you feel it out side by side. Was very happy with those tires.
Hybrids and EV
