Results 1 to 5 of 5
- May 2006
- 424
February 25th, 2011 05:57 AM #1i have an L3... the prob is the car falls to the left whenever I would let-go of the steering during driving...
so i went to servitek..suggested to wheel aligment and balancing...
after check up, some worn out parts were replaced (bolt joints, idler arm bushing, draglink assembly) and had the L3 balance and aligned....
but then, the prob still exists... now the servitek crew doesn't know what to do next except guessing... baka raw may konting dikit sa brakes, old tires (need replacements na raw) etc...
Anybody can help?
I need an answer but not guess..
Thanks
- Jun 2010
- 258
February 26th, 2011 12:42 PM #3
first step pa check mo ang gulong mo baka uneven wear,oblong,pressure at mga pang ilalim baka meron na kailangan palitan pag tapos na baka kailangan pa wheel/camber alignment ka na rin.
- Jul 2003
- 573
February 26th, 2011 08:04 PM #4if you are from the south of manila, I suggest to bring your ride to Shell Customer Cradle along Zapote Alabang Road, fronting PHCRMC.
thay have good technicians there and good equipment to verify wheel alignment before doing anything else.
- Jul 2010
- 165
February 28th, 2011 11:56 AM #5If everything was replaced, aligned and cambered correctly. The next thing to check is the tires.
Monk-owned R53
