Page 244 of 341 FirstFirst ... 144194234240241242243244245246247248254294 ... LastLast
Results 2,431 to 2,440 of 3407
    Oct 2017
    #2431
    Thanks guys!
    I guess more than running out of battery, it's preventing a battery leak that I'm trying to avoid.
    Nov 2017
    #2432
    hello worth it pa po ba bumili ng forester ngayon? Choices ko po kasi 2017 Forester 2.0i-P or the all new XV TOTL. Can you guys give me insights po to help with my choice ty!
    Aug 2017
    #2433
    Quote Originally Posted by josekuj View Post
    How about Forester 2018?
    Sent from my ... using Tapatalk
    Nov 2017
    #2434
    Quote Originally Posted by sprokolok View Post
    yes basta po yung latest this year
    #2435
    Anyone knows where to have my steering wheel centered? Our forester is only about 4 months old. Nung ginagamit ko na medyo na feel ko na hindi naka center yung steering wheel. Sobrang liit lang naman ng bias around 10 degrees to the left. So pag naka straight 0 degrees yun steering wheel medyo nag leleft. Pinasok ko under warranty pina align ko suspension and wheel balance. Hindi naman na ayos ganon pa din. Ive already isolated na hindi sa wheel alignment ang issue kasi pag iniwan ko steering wheel hindi naman siya gumagalaw or nag aadjust. So sa tingin ko ngayon is yun steering wheel rod connections dapat i adjust and re center. Any leads? Thanks!
    most tire shops can do this service..
    but if youre under warranty..submit a complaint sa dealership free dapat alignment.. especially low mileage kapa and 4months. i have a feeling its a tire issue .
    #2437
    but if youre under warranty..submit a complaint.. free dapat alignment.. especially low mileage kapa and 4months
    Yes bro pinasok ko na sa warranty. They did wheel balancing and alignment last month. Pag balik samin ganon pa din. Lahat kami sa family na notice ito. Is it ok if ipasok ko ulit with the same complaint?
    yes.. hindi nila ginalaw yan in my opinion. busy siguro sa other billable stuff. basta under warranty ipitin mo lng sila. kung ayaw ka nila bigyan ng oras. go to their manager or escalate to whoever is higher - this person will make sure that service advisor will do their job.
    Contact Us | Subaru Philippines
    #2439
    Quote Originally Posted by s2kurt View Post
    If nothing is bent, tire pressures check out ok, wheel centering is a simple service alignment shops can do. Look for 1 w/ Hunter or Hofmann alignment equipment that has specs for your model. Some don't grab the complete yearly updates...they can cost $500 annually. Most shops hand a 30day adjustment warranty.
    Oct 2017
    #2440
    The Forester we got comes with the stock sound system that has the Bluetooth fone connection and all that.... if I were to upgrade it to one that could accommodate a reverse cam, what would you guys suggest?
    Or is it just simpler and cheaper to get one of those mirror dash cams with a reverse cam bundled in?
Subaru Forester
