Page 172 of 341 FirstFirst ... 72122162168169170171172173174175176182222272 ... LastLast
Results 1,711 to 1,720 of 3407
    #1711
    Quote Originally Posted by jisan948 View Post
    Does the i-L and premium have identical speed given that the premium has 2 mufflers?
    Both models have the same powerplant and tranny so they should be about the same in performance. If there is a significant difference in weight, the lighter one should go faster. The number of mufflers will not play a big difference unless you have a full IHE modification kit installed on another model.
    #1712
    Thanks on this one
    #1713
    Thanks on this one
    You're welcome, bro! If you need more speed, go for the XT model.
    May 2005
    #1714
    The 2.0 and 2.0 premium both use the same FB20 engine so if I'm not mistaken they both have single exhaust. The premium probably has a chrome tip add on.
    Has the local distributor launched the new facelift?
    I have to say, its better to get the current look now and avail of big discounts. Appearance-wise, the facelift does not improve on anything in fact it looks worse (ie. the mag wheels on the XT).
    I think the premium has only 1 muffler. I will check though as soon as I get the unit.
    Jan 2010
    #1716
    one muffler lang and 2.0i Prem. XT lang double exhaust.
    Mine is a Premium had it last october 2015, im more than satisfied. love its handling at high speeds, at 140kph stable sya
    at walang nginig, parang nasa 100kph lang ang feel mo kaya you will be tempted to floor the gas pedal more. hanggang yang speed pa lang ang naabot ko sa tplex. Loving it lalo na sa long drive...
    Quote Originally Posted by Capsaul View Post
    How do you like HU? Ok ba ang sound quality? Harman Kardon na right?
    Jan 2010
    #1718
    walang badge ng harman kardon yung speakers, hindi yata sya harman kardon, sa XT lang yata yan.
    im not particular sa sound ng HU, sakin basta may may EQ na ma adjust ko yung bass ok na sakin. what im
    disappointed is walang navigation. yun lang.
    pero ok na din kasi touchscreen na din sya with bluetooth pairing.
    Yup, even the XT does not have GPS. But can you connect thru BT and use waze?
    ...and here we go!
Subaru Forester
