Results 81 to 90 of 159
- Dec 2009
- 43
August 25th, 2017 11:53 PM #81
August 26th, 2017 08:56 AM #82
October 25th, 2017 04:23 PM #84
MAF sensors!
I was along quirino ave when the MAF suddenly died.
Had to restart the car several times and had to drive it very slowly to MI Manila bay. Buti nalang early morning at wala pang traffic.
Anyway, they had to replace the connector pins re flash the ECU i think kasi i was running too rich.
October 25th, 2017 05:33 PM #85
October 25th, 2017 06:11 PM #86
7 years running 8 next feb.
Replaced it twice na. Once in 2012 and another one last June.
Sent from my SM-G930F using Tsikot Forums mobile app
- Jan 2018
- 844
January 2nd, 2018 09:24 AM #87Hi,
I'm new to the forum and was wondering if the Subaru folks here with Direct Injection engines have had problems with carbon build-up in their intake valves?
I've read in other forums that the intake valves get gunked up because with Direct Injection, the injectors are now inside the piston cylinder instead of the intake chamber. Thus, any cleaning agents in the gasoline are not being sprayed on the top of the intake valves which causes carbon deposits to build up over time.
Others have resorted to walnut shell blasting and installing AOS and EGR deletes as maintenance and prevention.
Anyone care to comment on their experience? Thanks!!
January 2nd, 2018 11:29 AM #88
January 2nd, 2018 11:50 AM #89
Problems I encountered with my 2012 Subaru Forester SH 2.0XS as of today 11,09x km (yes not a typo)
CEL(Check Engine light) lights up
First incident 1st half of 2016. CEL lights and the vehicle goes in limp mode. Greenhills Motor Image casa diagnosis it as dirty MAF sensor (so they cleaned it as well as the throttle body). An error code is retrieved from the ecu.
Second incident Feb 2017. CEL lights up again. This time the vehicle does NOT go in limp mode. This time I disconnect the negative terminal of the battery. Dont do this bec this removes the error code from the CEL. The CEL disappears. I have the vehicle serviced (PMS) on June 2017 and I tell them what happened but they cant find any error codes (bec. I disconnected the battery)
Third incident. July 2017. I bring it back to Greenhills Motor Image Casa. Same error code, diagnosis, remedy/rectification done by M.I. greenhills as in the 1st incident. This time the SA tells me to use Caltex Platinum fuel. (Note: I always use Petron Blaze 100 since new). He says the Blaze burns (combust) too rich that it dirties the MAF sensor (which gives off the CEL).
So far, I have covered around 1,7xx kms since the cleaning and used only Caltex Platinum since then. No CEL so far.
Aircon
Outside smoke belch comes in.
Aircon compressor
When it engages, the sound is quite noticeable inside the cabin, even a passenger who doesnt know anything about cars noticed it and asked me about it.
This is probably my second compressor bec the first one developed a squealing noise when starting from a cold engine (when it came out of casa brand new) so was replaced under warranty (thats what the casa told me bec I didnt witness the actual process of replacment).Last edited by number001; January 2nd, 2018 at 11:58 AM.
- Jan 2018
- 844
January 2nd, 2018 03:39 PM #90Thanks for the responses, Egan101 and number001.
I hope the pictures I've seen with gunky intake valves are not a common occurrence in our engines. I would prefer to keep my engine stock so I'm wary of adding an AOS and/or EGR delete. Add to that any warranty claims may be denied due to these add-ons.
I guess another solution are regular Italian tune-ups; so I'll have an excuse to do balls-to-the-wall runs regularly.
*number001, good to hear that they replaced your compressor under warranty. I hope your new one serves you well for a long time.
Na lock ang Gcash ko, need verification pa and kasama sa list nila ang philsys ID paper, but when I...
National ID Law
