Results 21 to 30 of 72
- Sep 2021
- 749
February 1st, 2023 04:29 PM #21Authorities differ in opinion, but the consensus is that "senior citizen" na ang gulong starting at 6 years, and the longest you can stretch them is up to is 10. Replace na talaga at 10.
If badly abused sila, I'd say swap `em out for new at 6. If yung tipong makapal pa talaga (and low mileage, garaged out of the sun) baka pwede pa patagalin. Kakahinayang nga, as sated (but that's the scrooge in me speaking)
- 52,701
February 1st, 2023 04:39 PM #22good treads install at the rear.
installing the balder tyres at the rear, is akin to removing the feathers from an arrow.
the arrow will tend to tumble and not run true, and the car loses directionality and will tend to jack-knife when the brakes are applied.
February 1st, 2023 04:55 PM #23
I had the opportunity to use the spare tire when I suffered a blown tire in SLEX. I had to use the spare tire going to Tagaytay and back. Yun nga lang, the spare tire is limited to 80kmh. A few friends here in Tsikot were joking which was more agonizing - the flat tire or driving below 80kmh. Hahahaha
I went on to get a new set days later. I was supposed to get new tires early this year and I was just maximizing the life of the tires until one failed on me. Sarap Kaya feeling ng drive with new tires!
- Feb 2013
- 910
February 1st, 2023 05:11 PM #24
- Feb 2013
- 910
February 1st, 2023 05:18 PM #25It looks like it's better nga to put the thicker tire sets on the rear:
6 Common Tire Myths Debunked
- Feb 2013
- 910
February 1st, 2023 05:19 PM #26
- Feb 2013
- 910
February 1st, 2023 10:01 PM #27Here's how my front tires look by the way:
Do you have any comments on how bad their treads are? And why is the tread wear uneven and just more towards the outside edge? The wear on the rear tires look to be even.
- 52,701
February 1st, 2023 11:37 PM #28well,
there's the tyre wear bar that's built into the tyre tread.
then, there's the lincoln penny test. google it, po.
but one quick look at your tyre, it's obvious it's way past either of these.
then there's the age. tyres 6 years or older, even if still with good tread, are candidates for replacement.
but there's lively debate on this.
then, there's carcass failure. the so-called "oblong tyre" or "hernia tyre". one day, it might just burst.
known causes include manufacturing glitch, over- and under-pressure, trauma, e.g., curbed, pot-holed and such....
un-even tread wear usually suggests the need for camber, caster, and toe adjustments.
also, proper inflation pressures.
so why should bald tyres be replaced?
1. bald tyres offer diminished stopping power in certain road conditions.
2. bald tyres puncture more easily, because the thickness of the rubber is already thin.
3. we have to keep supplying carritones and smaller boats with these bald tyres, else they be forced to use more expensive "good tyres". heh heh heh.Last edited by dr. d; February 1st, 2023 at 11:52 PM.
February 1st, 2023 11:39 PM #29
- Feb 2013
- 910
February 2nd, 2023 03:50 AM #30Yeah, I did research about those methods on how to know if the tires are already candidate for replacement but what I really don't understand is where the wear bar on the tires is. I mean I see an arrow on the sidewall which is also a tread thickness indicator but I don't understand how to use it. I guess I'm just missing something here.
These are stock tires that were never replaced yet. My car is at 60K+ Km now. I drove at NLEX earlier at a constant speed of 60kph, lol, just to be on the safe side.
