Results 41 to 48 of 48
May 15th, 2023 12:37 PM #41
- 52,731
May 15th, 2023 05:53 PM #42
May 25th, 2023 06:11 PM #43
May 25th, 2023 06:22 PM #44
Kung mahina buga ng aircon ng Subie nyo, you can follow these steps:
1. Check freon pressure; recharge if needed
2. Check for leaks; replace o-rings if needed
3. A whining sound coming from your compressor upon engine start means it is lacking oil. Refill compressor oil regularly to extend life of compressor (2k fix including freon recharge).
4. If no leaks within hoses and still losing freon, check expansion valve. Replace only is the option for a broken expansion valve (worth 5k for the whole fix).
5. If no leaks and expansion valve is good but still losing cool air (or freon), check evaporator. Replace and then clean whole system (worth 14k for the evaporator plus all the other services).
6. If no air coming out from your aircon system, compressor might be dead already. Replace it and, check both evaporator and expansion valve.
A good aircon shop can do all these things. The big challenge will be when you need to source out a broken compressor.
- Feb 2013
- 910
May 27th, 2023 02:16 AM #45Thanks as usual, Egan.
Update to my issue:
Binalik ko sa CarTech service center and they were firm na hindi na daw kaya ng compressor yung freon spec amount na 400g. At hindi din daw sila nag totop up ng compressor oil. Dapat full flush daw yung gagawin which costs around 6K. They tried bringing it up to 400g again pero ganun parin talaga.
I brought it to Coolmate thinking na magiging mga 2K lang din yung freon recharge plus compressor oil top up. The discounted quote I got was 3K when I was there. Nag go na ko and recharge nila to 400g plus 40cc's of oil directly put sa compressor. Nawala significantly yung noise and it looks like my problem is solved. O-ring lang talaga cause ng leak.
Lesson learned talaga dito na hindi "it's all the same" ang mga gumagawa ng aircon. Na doble gastos ko because of that. Kung from the start pinagawa ko na sa EEB Aire (malayo nga lang kasi from my residence) na 1.8K lang ako kasama na freon recharge, o-ring replacement, and compressor oil top up dun.
Also, walang kwenta ang CarTech service center Taguig, hehe. I'll never go back to that shop.
- 52,731
May 27th, 2023 12:12 PM #46
- Feb 2013
- 910
May 27th, 2023 03:44 PM #47
- 52,731
May 27th, 2023 11:19 PM #48
Monk-owned R53
