Results 991 to 1,000 of 1521
- Nov 2010
- 165
- Nov 2010
- 165
January 21st, 2018 05:27 PM #992First time CVT user. Is it a necessity to put the gear in neutral during extended stop (stop light) like I use to do in my DCT ecosport?
- Jun 2004
- 1,311
January 21st, 2018 05:49 PM #994
- Nov 2010
- 165
January 21st, 2018 05:51 PM #995
- Jul 2015
- 9,583
January 21st, 2018 08:53 PM #996got to sit inside one again...the driver seat is ok...pero sa smallish side yung rear seats..
- May 2014
- 7
January 24th, 2018 03:17 PM #997
- Nov 2010
- 165
January 24th, 2018 05:13 PM #998seems fine naman. saw this article from honda. also found suggesting the same in subaru forums
Electric Parking Brake
"Drivers Seatbelt on? Check. No need to disengage the parking brake, simply press on the accelerator to take off"
A first for a production Honda vehicle, the HR-V’s new, standard Electric Parking Brake (EPB) is simpler, more convenient and comfortable to use than a traditional parking brake.
Engaging the parking brake now requires only a pull on a switch on the centre console.
To release the parking brake, the driver simply presses on the accelerator pedal, while the seat belt is buckled, and the transmission is in drive or reverse.
Or the driver can push the park brake switch again to turn off the electric parking brake.
The Electric Parking Brake makes hill starts easier when the HR-V is parked on a slope. As with a traditional manually activated parking brake, Electric Parking Brake functions on the rear wheels only.
HOWEVER, I found this in our manual.
Never drive while the parking brake
is set because this will cause unnecessary
wear on the brake linings.
Before starting to drive, always
make sure that the parking brake
has been fully released.
- Nov 2010
- 165
- Feb 2013
- 919
January 27th, 2018 02:39 AM #1000Just discovered a cool sub-feature (if you can even call it this) of the Hill Start Assist
If the slope is too steep for the Hill Start Assist to work and you depress the brake pedal, it will automatically engage the e-brake ;)
It looks like there will be a class-action lawsuit vs Mercedes in Korea. The assertion is that...
Hybrids and EV
