Results 1,061 to 1,070 of 1187
- Jan 2010
- 304
- Apr 2008
- 12
July 12th, 2016 04:36 AM #1062sir tanong lang po,
Nagpalit po kasi ako ng battery because ayaw na magstart ng sasakyan. Motolite battery pinalit ko, napansin ko lang po after changing battery, pag start ko po ng kotse na naka ilaw yung abs, vdc and hill assist sa gauge. Meron na po ba naka experince ng ganito sainyo? and tanong ko lang po ano solution. btw forester 2014 xt po yung unit. thanks
July 12th, 2016 06:44 AM #1063
July 12th, 2016 06:48 AM #1064
July 12th, 2016 06:50 AM #1065
July 12th, 2016 06:52 AM #1066
- Jul 2015
- 9,584
July 12th, 2016 07:44 AM #10671. Also no problem with the usual stuff.
2. If youre in "I" mode your description of engine's performance is spot on, my default setting is on "I" and yes i drive like a granny, except when i did 230kph on tplex just to test her out, Put it in "S" or "S#", if want more low end response. Plus you cannot compare your subaru to your diesel colorado, most of its torque is tuned downlow and good for pulling and hauling stuff, our subaru is for top speed and grip at the corners
3. Have you tried doing filling her up the doing your usual errands then filling her up again, i did 7.75kms/L thats with xmas traffic paranaque to alabang and back which is not bad compare to my old crv and rav4s
4. About the Interior, yes ive seen better, on par with rav4 and crv,
5. I have no problems with the lights, maybe becoz i have clear tints
Good day.
- Apr 2008
- 12
July 12th, 2016 02:51 PM #1068Abs, vdc and hill assist light indicator is on when i start the car while the (S) and the cruise contron indicator blinks.
Di ako mapakali kaya tinawag ko sa motor image gh, sabi theres a proper way/step to start up the car after changing the car battery.
To make it short, i have to bring the unit and pay 1500php for them to reprogram the car. Thank you po sa reply sir
July 12th, 2016 04:34 PM #1069
July 12th, 2016 07:38 PM #1070
just done 10,000 km already replaced the transfer case fluid w/ ravenol MZG 90. a lot thicker...
Suzuki JIMNY [merged threads]
