Page 157 of 164 FirstFirst ... 57107147153154155156157158159160161 ... LastLast
Results 1,561 to 1,570 of 1640
    Mar 2012
    #1561
    Quote Originally Posted by gastromd View Post
    Ganda sir. Ano po brand and size? Wala rin po ba rubbing? Tnks
    Jun 2009
    #1562
    No rubbing. Nitro terra grappler 265/70/17
    Mar 2012
    #1563
    Tnks. Also have GLS with the same mags and naliliitan ako sa stock tires. Malaki ba sir difference sa fuel consumption and nabawasan ba acceleration? Turning radius?
    Jun 2009
    #1564
    Haven't computed FC yet. Medyo mabagal ng konti sa acceleration, pero malakas naman vgt eh... Just push d pedal and halos same n din ng stock. Hehe
    #1565
    sir gastromb saan po kayo kumuha ng nitto terra grapler? at magkano?
    #1566
    O.T
    First time to get a 'check engine' light on my almost 5yr old gls. Any pointers before I head off to the casa tomorrow.
    TIA
    Oct 2004
    #1567
    Quote Originally Posted by doy View Post
    Cusco Oil Catch Tank with 15mm inlet (sorry for the dirty engine and slightly slanting tank mount):
    http://i6.photobucket.com/albums/y209/doy/Photo0514.jpg
    http://i6.photobucket.com/albums/y209/doy/Photo0516.jpg
    http://i6.photobucket.com/albums/y209/doy/Photo0515.jpg
    Tank is mounted firmly using the 2 stock protruding #4 stud bolts from the firewall (just remove the mounted plastic cable fasteners). Drawback is slightly slanting yung position ng tank (pero atleast secure ang tank kahit ihataw sa rough roads). Additional items used were two 3/4 inch hose clamps (for tank end), three #4 slim head bolts, nuts, washers, and lock washers (masikip if using the supplied #4 nuts and bolts; masyadong malaki ang ulo ng supplied bolts). Black hoses used is the stock 1-piece rubber hose cut in half for engine and intake end. The supplied 5/8 inch hose clamp was used to connect the stock rubber hose with the supplied barbed silicon hose (stiff kahit tight na ang hose clamp). Installation time is around 1 hour with some acrobatic moves around the engine bay during bolt tightening.
    Update:
    New oil catch tank position and mounting (sorry for the dirty engine):
    http://i6.photobucket.com/albums/y209/doy/Photo0706.jpg
    http://i6.photobucket.com/albums/y209/doy/Photo0703.jpg
    The stock two #4 stud bolts gave in. Luckily there was a bit of metal sheet holding one stud bolt pero nakayuko na ang can. Muntik nang malaglag ang oil catch tank ko! The stock stud bolts were just adhered to the thin metal sheet. Akala ko naka-bolt sa other side at makapal ang sheet kase firewall:
    http://i6.photobucket.com/albums/y209/doy/Photo0704.jpg
    The new position and mounting, hopefully, will be durable enough for high-speed offroad runs. I used one stud bolt (upper left corner) of the plastic engine block cover and inverted it to secure the mounting bracket of the oil catch tank from below:
    http://i6.photobucket.com/albums/y209/doy/Photo0705.jpg
    Oil catch tank height is just enough to clear the hood insulator and the can doesn't vibrate as much as I expected.
    May 2012
    #1568
    Hi mga Sir.
    Got my GLX Strada 2 weeks ago. Have been back reading a bit and I want to join the club. Just can't seem to find details on the next EB schedules.
    Wanna meet the gurus and get feedback on the usual Strada problems and solutions for the usual problems.
    Also wanna see other owner's units. Thread palang parang ang sarap mag mods. Pano pa kung actual makita!
    Hope to meet you guys soon!
    Oct 2004
    #1569
    Quote Originally Posted by jpego View Post
    Hi mga Sir.
    Hi, sir!
    Try nyo po dito:
    The Strada Club of the Philippines
    Apr 2006
    #1570
    Hi mga Sir.
    congrats sir and enjoy your ride!
    if you have facebook - request to be added here ----> https://www.facebook.com/groups/32557704936/
    kita-kits..
TSCP Strada Mods [continued 2]
