Results 1,411 to 1,420 of 1640
November 28th, 2011 03:40 PM #1411
- Feb 2010
- 7
November 28th, 2011 04:42 PM #1412Bro doy,275/70r16 ang tires.
Bro weng2, ayan di ako sure pero parang -42 (not sure). Almost 3" ang labas. Medyo teeth grinding lang nung nag shave ako ng mudguard and rear fender wall.
November 28th, 2011 04:51 PM #1413
Yup, tama ata ang 4 inch front space para sa desired look mo. Compared the specs of other 9-inch wide wheels with 0-offset and their backspace is also 5 inches. Iba-iba talaga ang fitting. I believe the look you'll have is similar to this:
http://i33.tinypic.com/30cbtjd.jpg
November 29th, 2011 10:07 AM #1414
November 29th, 2011 10:21 AM #1415
bai, sobrang labas naman ng gulong nitong montero na naka 7031. pinakita ko ang pic sa auto options at sabi nila baka nilagyan daw ng spacer. based on my measurements of the stock montero rim and compare to the actual front space of the 7301 (4.0"), mga 1/2 to 3/4" lang ang stick out (depending on tire inflation din)
November 29th, 2011 11:11 PM #1416
- Oct 2003
- 101
November 30th, 2011 01:04 AM #1417bro, this is weng2, di ko napansin naka default sa other computer ko ang account ng aking bro.
i'm from ormoc, leyte and bought the st maxx from the distributor in cebu. the price i paid is cheaper than ryco coz a friend who has an account with the distro helped me purchase them.
November 30th, 2011 03:44 PM #1418
ah I see....if you dont mind can you PM me the price? Im targetting this to be the next set that I will buy....thanks bro!
- Oct 2003
- 101
November 30th, 2011 05:09 PM #1419i sent you a pm yesterday but it won't go through. your inbox is FULL.
December 1st, 2011 12:43 PM #1420
Update:
2 days after the oil catch tank install (18K+ milleage):
http://i6.photobucket.com/albums/y209/doy/Photo0518.jpg
http://i6.photobucket.com/albums/y20...0519edited.jpg
Notice the oil collected at the encircled area. I believe it's best to install an oil catch tank even as early as 10K milleage (after the free PMS labors).
Traffic!
