Results 11 to 19 of 19
March 29th, 2010 10:21 AM #11
You can try disabling the password totally and try testing if you can connect.
March 29th, 2010 11:01 AM #12
had also happened to my D-link serries N. yung acer laptop ko pwede but not my daughter's toshiba and wifi phone. ni-reset ko with NO password, hayun ok na lahat. di ko na nilagyan ulit ng password dahil wala naman akong alam na may wifi capable sa mga neighbors namin.
to answer TS question... very significant ang difference nila in terms of coverage. yung sa akin pwede ko pang gamitin sa labas ng bahay with 3-bars sa connection indicator.
March 29th, 2010 12:34 PM #13
In my case, I use my N router without password but I enabled MAC number security as alternative to WPA security which is having problems.
- Nov 2002
- 1,326
March 29th, 2010 01:50 PM #14kung walang WPA password but with mac filter... meaning i have to register manually yung mga mac addresses ng mga machines that i allow to use the wifi at home before they can use it?
hindi kaya uubra na tipong AND/OR? like for machines i'm having trouble with connecting through WPA-TKIP, i'll force the MAC FILTER to take over, while for those that have the right password, hindi na kailangan setup yung MAC FILTER?
got relatives kasi who visit often during the day (habang wala ako sa bahay) and they use wifi ...
March 29th, 2010 04:07 PM #15
- Oct 2008
- 380
March 30th, 2010 06:05 AM #16
March 30th, 2010 08:55 AM #17
The MAC filter cannot be used in a "and/or" with the WPA. So either you get the WPA working or use the MAC filter. IF relatives visit often, then you should input their computer's MAC number into your router's MAC list.
If not, you might have to fall back to WEP security. Downside, WEP security means you cannot use "N" protocol and speed.
March 30th, 2010 08:58 AM #18
April 1st, 2010 02:49 AM #19
wala din password yung router ko but i use the MAC FILTER the other way around.
minsan kasi, madami friends ng anak ko ang nasa bahay using wifi. so instead of inputting their mac #, i block unwanted connections na lang using a MAC scanner..
so far, 4 pa lang yata ang nablock ko since last year..
ang dapat na yearly emissions testing ay ang mga PU vehicles. we see a number of them on the road,...
LTO accredited emission testing centers
