Page 1 of 2 12 LastLast
Results 1 to 20 of 22
    All of my devices can connect to this router but only my PC ad iPads have internet while my iphone, ipod and laptop don't have internet.
    Here's the setup of my network:
    DSL modem --- router1 --- (bridged / wireless) --- router2 --- (utp cable) --- router3
    All the the routers are wifi. Only router1 have DHCP enabled.
    Only router3 has the no internet problem with some devices.
    I've already restored router3 to factory settings and reconfigured it but still the problem persists.
    Jan 2010
    Based on your illustration, router2 should have its gateway set to router1's IP, while router3 should have its gateway set to router2's IP.
    If router1 is set to DHCP, then router2 is getting a dynamic IP, unless you set router2 to a static IP outside the DHCP range of router1. If router2 has a dynamic IP, then what IP is router3's gateway set to?
    Maybe you can check from there?
    BTW, I am assuming you've done preliminary troubleshooting like directly connecting router3 to the DSL modem and successfully getting internet connection, and that you've established you don't have any hardware issues.
    My preference is to manually set ROUTER2's & ROUTER3's gateway setting pointed to ROUTER1's address. I think it would help decrease the lag for connections using ROUTER3.
    BOYBI: is router3 that much further away from router1 that you cannot directly connect it?
    Anyway, I haven't done a network setup similar to the one illustrated above. Usually it's all other routers are directly connected to a single central router.
    Jan 2009
    Just for clarification, you're not using the WAN port on router2 and router3? And that they're both only setup as access points, with the routing function essentially not being used?
    In which part of the router config do I set the gateway? In the WAN part?
    If yes, then do I set the WAN connection type to Static IP? Because it's only with this connection type that I can manually set the IP and gateway. But if I input the IP of router1 as the gateway, it gives a Bad WAN for Gateway IP error.
    *GH, router1 is in my office across the street. router2 is placed outside the window of the room facing the office and is connected to router1 wirelessly. My room is in the other side of the house and not facing the office. The signal of router2 can't reach my room that's why I need router3.
    This only happened when I changed my ISP from PLDT to Globe. The only thing that was changed was when I'm with PLDT, it was router3 which was connected to the DSL modem. Now with Globe, it's router1 that's connected to the modem.
    Did you use 192.168.1.xx format for both routers? You can try changing the router2 IP set to 192.168.2.xx and router3 to 192.168.3.xx to avoid conflicts. So when you set the WAN gateway in router2 and router3, you can set it to 192.168.1.xx.
    Just remember to write the new address on the router's body (masking tape, post-it notes, etc) so you don't forget in the future.
    I am assuming all routers are wifi-N type routers?
    I'll try to change the IPs of my routers later when I get back home.
    All my routers are only G-type. I used an external antenna for router2 so it can communicate better with router1.
    In my experience, upgrading to WiFi-N type router increases the range of the signal, especially if your devices are already WiFi-N enabled. This is especially true with N-routers with multiple antennas.
    Also given that WiFi-N adapters are relatively cheap, it might be worth the money to upgrade older WiFi-G stuff to the N standard.
    Brand I prefer is TP-LINK. Cheap with reliability & good performance.
    Thanks GH, I did what you suggested and it worked!
    But I find it weird that before this, some of my devices have internet while others don't.
    My guess, with all three routers set on 192.168.1.xx, the IP assigned by DHCP to your devices gave it a random chance to either have a connection or have a conflicting address which resulted in no internet connection.
    I assumed that each IP address assigned to each device is meant to last a few hours before expiring. So a device connected today may have problems connecting a few days later.
    My iPhone still doesn't have internet. All my other devices can connect to the internet already.
    Upon checking the IP of my iPhone, it was assigned an IP of 169.254.xxx.xxx.
    I suggest you reset the router where the iphone attempted to connect. That should let the iphone get assigned a new IP address inline with the 192.168.xx.xx set.
    That did the trick. Ang bobo ko talaga sa mga network ekek
    Don't blame yourself if you can't solve the problem. Sometimes it is easier to solve a problem if you aren't in the middle of it.
    I am just glad that my network config skills are still something so many years after I have left working as a computer network tech.
    Yes TP-LINK is proven already and is cheap but reliable. Ok din warranty service.
    My iPhone can't connect to the internet again when using router3. I reset router1 & router3 but the iPhone was always given an IP of 169.xxx.xxx.xxx.
    May 2011
    router3 according to you is NOT DHCP enabled that is why you are not getting a valid IP.. -Enable DHCP on router3 and make sure it gives you IP range same as router1
    Quote Originally Posted by xninjax View Post
    But why does my other devices able to obtain a valid IP from router3 and not my iPhone?
    May 2011
    hmmnn indeed. 169.xxx.xxx.xx is usually automatically assigned when DHCP connection fails (read up on APIPA) I just dont know why it happens only to your iphone. ugh..
Connected to wifi but no internet
