Results 121 to 130 of 169
January 24th, 2006 10:44 PM #122
hmmmmm
baka mali lang pagkaburn ko. hehehe
ayos ba ung xandros? pano ako mag iinstall ng mga apps? madali lang ba? pwede bang direct install na nung mga apps ng windows? o may separate installer ung pang linux/xandros. ung ibang apps kasi may separate pang linux. since mukhang hi-tech na tong xandros baka pwede na diretso.... hehehe.
January 24th, 2006 10:48 PM #123
unfortunately I was just trying different flavors of linux because of the licensing push of MS. I didn't get very far into getting applications ported over from MS to Linux though. If I remember correctly, most of the "plug & play" Linux already has some word processor and spreadsheet apps included.
January 24th, 2006 10:59 PM #124
ah ok. most of the apps na kelangan ko naman e designed for linux, kaso lang ang problema kelangan ko mag dl ulit. hay buhay.
BTW. how do you burn the installer CD? what i did is i extract the iso file and burn it into a blank CD. i dont know how to burn iso files. hehehe
January 24th, 2006 11:24 PM #125Originally Posted by fLaKeZ
to burn an ISO file to CD, simply use your software (I use NERO) and choose burn CD from file option. The resulting CD will be a copy of the original source CD.
January 24th, 2006 11:26 PM #126
you burn iso files using alcohol120% or daemon.hindi pwede yung ordinary nero =)
January 24th, 2006 11:33 PM #127
wouldnt it result to an ISO file? or it will extract itself while burning in to the cd? i remember i tried burning an iso file before but the result is still an iso file. hehehe. anyways, thanks. i guess i'll just have to try it again.
January 24th, 2006 11:39 PM #129Why not Linux? (WinXP + MS Office Pro cost P28,700)
Another irritation I've encountered in the past with Linux is the repeated dependencies on top of dependencies when all I want to do is update a piece of software. Granted, I was using Mandrake (rpm). But even updating in Debian-based distros (deb) is still not as easy as in XP.
Having said those, I have used the freebie Mandrake since version 6 and have boxed distros of SUSe 7.1 and 8.1. Right now, I've started using Linux LiveCD's instead of installing them outright. I use Linux mainly for surfing when I feel like using Linux. The relatively low number of excellent commercial 3rd-party apps makes it less than compelling for now, free or not.
the triumph of man over... man!, using the crudest of implements (by modern standards).
Traffic!
