Results 21 to 28 of 28
June 15th, 2009 08:31 PM #21
A couple more ideas:
-audio listening system through laser reflection.
Theory: you can listen to sounds and conversation in a closed room by reflecting a laser beam on a window and converting the reflected light into sound by electronics.
Problem: you will need a sensitive light sensor to act as receiver.
-Auto Guided Vehicle (AGV)
Theory: using sensors, an unpiloted vehicle with move from point "A" to point "B" and back using only onboard sensors.
Idea: this is basically a simplified version of the AGV robots used in industry to move items from production workstation to production workstation. I also built a few robots of this type back in college (more complex due to requirement of programability). The vehicle will follow a strip of reflective tape on the floor. The tape will be in a form of a closed loop. There will be two stop points along the loop to be designated as point "A" & "B".
How to do it: simple... Use two 4-wheel-drive toy cars to be the chassis 7 drive system of the vehicle. On the left side toy car, remove the right side wheels. On the right side car, remove the left side wheels. Attach them together and they will form a crude four wheel vehicle with basic steering by either powering the left or right side to turn and powering both cars to go forward.
Sensors and electronics: ALEXAN has a light sensor kit being sold. You'll need three sensors (left, right and stop). You'll also need three flashlights as light emitters.
-Long Distance Direction Transmission of Sound
Theory: using laser, transmit sound to a receiver.
Practical use: long distance line-of-sight communication without potential of interception
Hardware: Audio to laser converter and laser receiver to sound converter.
See if those interest you. I can explain the gaps in the info later if anyone is interested.Last edited by ghosthunter; June 15th, 2009 at 08:43 PM.
- Feb 2008
- 144
July 5th, 2009 08:52 PM #22sir GH, emergency po! ni-reject ni mam yung proposal namin (na in-approve naman nya nung una) sa di malamang dahilan, meron ata. at kelangan namin ng bagong proposal. parang magganda yung AGV pero sa pagkakaalam ko yung principle nun eh na-apply na ng Lexus sa ilang kotse nila(correct me if im wrong). kelangan kasi eh orig(or at least wala sa internet) yung idea.
sa mga na-suggest mu earlier, alin ba dun yung orig? parang maganda yung hydrolic na arm, please explain that further.
July 5th, 2009 10:21 PM #23
It will just demonstrate the principles of hydraulics with cheap syringes.
Basics, if you fill two syringes halfway with water and connect the two with a water filled tube (no air), if you press on the plunger of one syringe, the other syringe will move backward (extending the length).
In that idea, you can make an arm with claw which will use the syringes to move and those syringes will lead to either a set of levers to move the arm or a frame which is strapped on your arm to make the 2nd arm mimic your movement.
Another possible project is a power amplification frame. The concept is it is a mechanical frame with motors linked to its joints that a person wears. It will copy the operator's movements and add power to the movement. So if you push with 20 pounds of force, the device will add 200 pounds of more force. As a whole, it can help lift and move heavy objects.
As your school project, you may just make an arm frame. You can use a wiper motor as the actuator. A pair of limit-switches would make the motor move slow or fast in a certain direction.
July 5th, 2009 10:31 PM #24
Tsikot Member Rank 4
- Jan 2007
- 2,326
July 8th, 2009 04:56 AM #25
July 8th, 2009 08:54 AM #26
- Feb 2008
- 144
July 8th, 2009 08:35 PM #27
Ok sir, thanks again.
kaya lang application of knowledge yung gagawin namin at hindi po demonstrating the principles of an existing knowledge, so parang mag- iinvent kami. parang hindi pala kasi appropriate yung hydraulic joints.
I just researched about the van de graaf generator. parang magandang i-project yon at madali lang naman mag-improvise. generating electricity using man power. sirang bisikleta lang o ano mang blahblah ang magpapaikot sa generator. what do you think?
July 8th, 2009 09:04 PM #28
static electricity generator. If that would pass through your teacher. But it's not as easy as you might think.
Daming issue ng SU7:grin:
Xiaomi E-Car
