Results 11 to 12 of 12
November 19th, 2007 06:55 PM #11
I see. The high costs of servers is not just because of the hardware, but also the software (server editions of OS are typically used for this), as well as the support provided by the manufacturers.
You still can have a desktop that's reliable enough to run almost 24/7 without purchasing a server, if your needs are those mentioned by Mguy above. You just need to add a few peripherals (eg, a surge suppressor, UPS, another hard drive for a RAID configuration, etc.) as well as critical and hardware monitoring software to make sure you are alerted if your PC is nearing the failure point.
However, for critical applications like those mentioned by Mguy, you really need to use a server.
November 20th, 2007 08:53 AM #12
In addition, a desktop workstation usually comes with a 1 year warranty, the server with 3 years, with options for extended warranty and preventive maintenance service.
Suzuki JIMNY [merged threads]
