Malinaw kahit non abs-cbn channels. May mga demo units sa mall dito sa cavite.
does it mean i can still get gma, tv5, and the ABS-CBN networks on this (Studio 23, etc...)? baka kasi puro ABS-CBN channels lang..... thinking din kasi of getting this...
and can i connect a cable coax din sa likod nung blackbox so i can get my cable channels (e.g. HBO?)
yung cable kasi namin (Cablelink) walang DZMM, and other ABS-CBN channels so I am thinking of using this simultaneously with the cable connection.
I dont know about the connection. Di ko natry.
Yes. You can watch:
abs cbn
abs cbn sports and action
Gma
Gma news tv
Tv 5
Aksyon tv
Dzmm
Knowledge channel
Cinemo
Some area may jack tv at 2nd avenue pa
Mas maganda pag nasa labas ang antenna. Yung nasa loob ng bahay antenna 4 channels lang meron. Nung nilabas ko nagsilabasan na rin yang mga channel. Except wala ako nung jack tv at 2nd ave
^^ yes, you'll get non-abs-cbn channels in metro manila
no, your cable coax carries analog tv channels while the blackbox will only process digital tv (isdb-t standard) ... you will have to connect the blackbox on the AV input of your tv (using the supplied rca cable), while the cable coax remains on the Antenna input of the tv
gusto ko sana magpainstall neto sa sasakyan, kaso di pala magagamit yung mga buttons sa steering wheel para maglipat ng channel.
I'm not familiar with Cablelink. But with my Skycable subscription, I won't be able to connect the coaxial cable that carries digital signal to the blackbox because the digital signal is encrypted. The dedicated Skycable box actually functions as a decoder.
Hi,
I'm interested to buy this and install it on my 2011 tucson. I have a DVD/GPS screen with Analog TV function (replaced the standard HU). Can I remove the analog TV and replace with this one? I believe you will need an inverter. Is this an easy setup? How much in average is the inverter for this?
Thanks
No, because the analog tv of your HU is a built-in feature. However, if the HU have AV input, then you can connect the blackbox to it.Can I remove the analog TV and replace with this one?
You don't need an inverter for the blackbox. It accepts 12V dc power. It comes with an AC adapter with 12V dc output for home use.
may RF in/out yung mahiwagang blackbox. pag analog cable ba pwede dito nakasaksak yung cable?
Very high probability, yes. It can output both Composite and RF... para sa mga legacy TVs.
But ironically, my bedroom Samsung LCD TV only has HDMI, Component, and VGA inputs.... no Composite. I have to use RF to receive the signal from the box through analog CH3 on the TV.
It's the 1980s all over again.
^^ mine naman meron composite pero useless din pala tong high def LED ko kung ala naman composite out man lang ang blackbox kundi RCA out lang. Better use CRT TV na lang kaya. hehe
