Page 3 of 9 FirstFirst 1234567 ... LastLast
Results 41 to 60 of 168
    #41
    Malinaw kahit non abs-cbn channels. May mga demo units sa mall dito sa cavite.
    #42
    Quote Originally Posted by dct View Post
    Sa ncr, meron gma gma news tv, tv5, aksyon tv, at kung ano ano pa. Hindi lang abs. In fact mas malakas pa ang gma.
    At kahit lubak lubak ang daan, clear na clear pa rin yan
    does it mean i can still get gma, tv5, and the ABS-CBN networks on this (Studio 23, etc...)? baka kasi puro ABS-CBN channels lang..... thinking din kasi of getting this...
    and can i connect a cable coax din sa likod nung blackbox so i can get my cable channels (e.g. HBO?)
    yung cable kasi namin (Cablelink) walang DZMM, and other ABS-CBN channels so I am thinking of using this simultaneously with the cable connection.
    Jun 2012
    #43
    Quote Originally Posted by 1D4LV View Post
    I dont know about the connection. Di ko natry.
    Yes. You can watch:
    abs cbn
    abs cbn sports and action
    Gma
    Gma news tv
    Tv 5
    Aksyon tv
    Dzmm
    Knowledge channel
    Cinemo
    Some area may jack tv at 2nd avenue pa
    Mas maganda pag nasa labas ang antenna. Yung nasa loob ng bahay antenna 4 channels lang meron. Nung nilabas ko nagsilabasan na rin yang mga channel. Except wala ako nung jack tv at 2nd ave
    #44
    ^^ yes, you'll get non-abs-cbn channels in metro manila
    no, your cable coax carries analog tv channels while the blackbox will only process digital tv (isdb-t standard) ... you will have to connect the blackbox on the AV input of your tv (using the supplied rca cable), while the cable coax remains on the Antenna input of the tv
    Jan 2012
    #45
    gusto ko sana magpainstall neto sa sasakyan, kaso di pala magagamit yung mga buttons sa steering wheel para maglipat ng channel.
    Dec 2014
    #46
    I'm not familiar with Cablelink. But with my Skycable subscription, I won't be able to connect the coaxial cable that carries digital signal to the blackbox because the digital signal is encrypted. The dedicated Skycable box actually functions as a decoder.
    #47
    Quote Originally Posted by kinyo View Post
    ah ok. pwede pala pagsabayin. thanks.
    #48
    Hi,
    I'm interested to buy this and install it on my 2011 tucson. I have a DVD/GPS screen with Analog TV function (replaced the standard HU). Can I remove the analog TV and replace with this one? I believe you will need an inverter. Is this an easy setup? How much in average is the inverter for this?
    Thanks
    #49
    No, because the analog tv of your HU is a built-in feature. However, if the HU have AV input, then you can connect the blackbox to it.
    You don't need an inverter for the blackbox. It accepts 12V dc power. It comes with an AC adapter with 12V dc output for home use.
    Sep 2013
    #50
    After reading your post, that setup is similar to VCR with build in TV tuner where the coax cable is hooked up to VCR, then from VCR AV output to TV set A/V input.
    Quote Originally Posted by luis_ View Post
    Baka usual tv tuner gamit mo sir hindi black box na pang digital kasi sa pagkaka alam ko abs palang nag didigital broadcast. Wala pa ibang channels
    Nope! You're wrong.
    Ok Ito kung ganyan pwede ba Hdmi connection to TV parang mgs digital media player or Walang HDMI connection Ito.
    So I short. Pag pagssbayin Ito with your existing cable and you want to watch like DZMM you have to switch to your AV/component/Hdmi channels?
    #53
    may RF in/out yung mahiwagang blackbox. pag analog cable ba pwede dito nakasaksak yung cable?
    #54
    Quote Originally Posted by kimbon View Post
    correct!
    walang HDMI ang blackbox (although the board itself have unused provision for it, possibly for the next rev build) ... yes, on the tv you simply switch to AV (source)
    So how much is this box?
    #56
    its 2,500.00
    its 2,500.00
    #57
    ^ P2500 ... includes a free abs-cbn sim card
    Bakit kaya wala pang HDMI itong box? Dahil sa target market nila?
    Jan 2009
    #59
    Very high probability, yes. It can output both Composite and RF... para sa mga legacy TVs.
    But ironically, my bedroom Samsung LCD TV only has HDMI, Component, and VGA inputs.... no Composite. I have to use RF to receive the signal from the box through analog CH3 on the TV.
    It's the 1980s all over again.
    Sep 2013
    #60
    ^^ mine naman meron composite pero useless din pala tong high def LED ko kung ala naman composite out man lang ang blackbox kundi RCA out lang. Better use CRT TV na lang kaya. hehe
Question about ABS CBN TV PLUS (BLACK BOX)
