Results 21 to 28 of 28
- Nov 2009
- 3,484
January 28th, 2015 01:57 PM #21^ ADSL will suffice since application is more on download. Just check the telco with best data limit and CIR ratio. They don't usually advertise CIR but as a client you have the right to know.
Committed information rate is the way telco budgets the bandwidth in the aggregator routers. Lets say the advertised port speed is 10mb then u got a 1:16 cir this means your bandwidth should not go below 625Kbps at anytime of the day even if the shared bandwidth has been fully utilized.
January 28th, 2015 02:29 PM #22
- Nov 2009
- 3,484
January 28th, 2015 02:43 PM #23Alam ng csr. During application, alam din ng sales. Hindi lang talaga inaadvertise dunno why. Siguro dahil residential its considered as value added services, NTC has no rules re port speed vs committed speed. Sa leased lines naka stipulate sa contract both.
- Aug 2014
- 391
January 28th, 2015 04:00 PM #24usually, pag adsl, walang CIR, pero merong minimum na nasa SLA pa ila, halimbawa, yung globe, 3MBPS, pero SLA nile, basta kaabot ka 512kbps, ok pa... pero most of the time, umaabot ka nang download na almost 3mbps... upload though is lesser that download..
pero sa corporate naman... like what we have at the office, we have 20mbps..yung upload/download nun.. halos mag kapareha, pero depende pa din yung sa final source/destination.. it varies.
- Aug 2014
- 391
January 28th, 2015 04:00 PM #25usually, pag adsl, walang CIR, pero merong minimum na nasa SLA pa ila, halimbawa, yung globe, 3MBPS, pero SLA nile, basta kaabot ka 512kbps, ok pa... pero most of the time, umaabot ka nang download na almost 3mbps... upload though is lesser that download..
- Nov 2009
- 3,484
January 28th, 2015 04:30 PM #26Kung 3mb ang port speed at 512k ang committed, then 1:6 ang CIR (512/3072).
Sa corpo 1:1 ang most requirement since you have servers and delay-sensitive voice apps na upstream dependent.
June 16th, 2015 08:19 PM #27
update: nakabitan na din ng pldt sa wakas!
turns out that dsl and fibr facilities are different. available pala sa lugar namin ang fibr so we subscribed. nagtataka lang ako di sinabi ng pldt to nung una kami nag apply.
- Nov 2009
- 3,484
June 16th, 2015 08:55 PM #28Fiber uses optical mux, ADSL uses DSLAM. Both provides data connectivity using different physical medium(fiber optic/ copper wire). Copper cables are the old infrastructure while optical has been there for a while but its getting more affordable.
