Results 11 to 15 of 15
March 31st, 2008 05:12 PM #11
try downloading on piratebay. madaming seeders dun :pirate2:
March 31st, 2008 10:32 PM #12
If you're using Windows XP, meron siyang Half-Open TCP Connection limitation which causes some problems with P2P programs. If this is so, you should also try to remove this limitation.
April 2nd, 2008 05:45 PM #13
> first, you need to find another ******* and has the same file name and contents and file sizes.
> copy those ******* trackers via ******* properties (advanced option)
> trackers looks like these:
http://open.tracker.************.org/announce
http://www.*******-downloads.to:2710/announce
http://denis.stalker.h3q.com:6969/announce
udp://denis.stalker.h3q.com:6969/announce
http://www.sumotracker.com/announce
http://pirates.sumotracker.com/announce
http://tracker.prq.to/announce
http://atlantis-stargate.no-ip.info:6969/announce
there are also public trackers that you can copy paste without looking it up for similar ******* like piratebay's tracker and tracker.prq.to
May 10th, 2008 06:19 AM #14
This tweaking works. Just tried it last night. Follow the entire procedure including patch.
http://triponic.com/guidestutorials/...rent-settings/
May 10th, 2008 06:37 AM #15
bro reklamo mo yan sa pldt, ganyan din yung speed ko dati eh... kailangan at least 200 DL speed mo sa speedtest.net. connect to singapore.
Did some independent research and decided to go with the white pearl crystal.... para maiba naman. ...
