Results 11 to 20 of 22
- Oct 2009
- 2,271
July 28th, 2015 03:21 PM #12mag request kayo ng signal booster sa opisina nyo.
kagaya ng ng nasa parking ng 168 mall
kahit na sa ilalim na ilalim may signal parin
- Jan 2014
- 655
July 28th, 2015 03:32 PM #13Wala kayong indoor antenna sa building? Ayun yung mga hugis cone na kulay puti at madalas may sticker ng telco pag nag punta ka sa mga malls may mga ganun nasa ceiling nakalagay. Repeater lang yun bale na naka connect sa amplifier para sa mga dead spot ng building. Malakas talaga kasi yung drop ng signal kapag madaming interference. Dapat makipag coordinate yung building admin sa telco. Hindi dapat dahilan yung crowded kasi lugar nyo dahil pwede naman lagyan ng mga ganun halimbawa na nga lang ulit yung mga malls. Napakalawak pero kahit nasa gitna ka may signal at madami pang tao nun ha
July 28th, 2015 03:42 PM #14
Tawag dyan, Inbuilding Solutions. Request nyo sa Telcos. Usually yang bldg admin nagrerequest nyan.
July 28th, 2015 04:04 PM #15
July 29th, 2015 10:47 AM #16
sinong magsoshoulder ng gastusin pag pinakabitan ng mga cone type signal booster? telco or building owner?
July 29th, 2015 10:57 AM #17
Yes they can do that (boost the signal of cellsite signal) and you just have to report to their hotline at baka magawan pa paraan. Pero kapag booster na machine ang kelangan na, dapat mataas traffic nang usage para kabitan ang isang bldng. Try niyo mag-request (lalo na kung yung building woners/manager mismo gumawa nang request) at baka puwede naman kayo lagyan signal booster sa bldng niyo.
July 29th, 2015 11:06 AM #18
depends on the arrangement...... pag entire building, yung building owner.
pag sa area nyo lang, kayo...
BANNED BANNED BANNED
- Jul 2013
- 421
July 29th, 2015 08:03 PM #19palagay ko, walang jammer diyan dahil pwede sa labas ng window.
your best bet, install an outdoor ant. its called a colinear ant; yong 8 elements.
i'm not sure about the freq; maybe 900mhz, 2.48ghzz or 5.28ghz. before it was 900mhz. magpunta ka sa raon and buy an 8 element colinear ant. of course, it should be installed outside the window, if it works inside, di ok then buy the cleapest cp and use it as your general calling cp. medyo hassle at tedious but it is the cheapest setup.
by the way, the ant cost P200 -1500 depending on q.
[COLOR="silver"]- - - - - - - - - - - - - - - - - - - - - -Last edited by pyramid00; July 29th, 2015 at 08:06 PM. Reason: double post
- Jul 2013
- 421
July 29th, 2015 08:15 PM #20additional info: consult an electronics technician at magpagawa ka ng ground plane ant w/c should cost much lesser. narealized ko, pwede pala kung outside the window. a simple gp will do the trick.
95% of the cost goes to the cable, either 50 or 75 ohms. buy an ant assembly with a proximy/piggy back connection.
Monk-owned R53
