Results 21 to 24 of 24
September 25th, 2006 01:19 PM #21
September 25th, 2006 03:47 PM #22
Oo nga... it just gets my ire that they ban cellphones at the pumps... one company states that it's not the RF signals or microwave signals... it's the possibility of sparks daw from defective keypads.
If this is true, they should ban the digital keypads on new gas pumps, the flourescent lights overhead, and they should have all car-owners stop their cars twenty feet away, disconnect the batteries and remove them, and push the cars up to the pumps.
Madness, I tell you... madness!!! Bwahahaha...
September 25th, 2006 04:18 PM #23
actually, mythbusters proved that this theory is quite correct, but only to american signals (GSM 850 ata yun or 900).
September 25th, 2006 05:12 PM #24
Actually, what they proved is that the signals from older phones (I'm assuming non-GSM) have an effect on unshielded equipment. Their test equipment was so poorly shielded that when they took it out of the faraday cage for a real world run, they went crazy.
Their follow-up test inside a real plane (sitting on the runway) produced no discernible deflection of the instruments. An engineer explained that because modern airplane instruments and equipment interfere with each other, the equipment on the aircraft is very well shielded... thus, no interference from cellphones.
Thus, if a cellphone can cause equipment to malfunction, that means the shielding has failed, and most likely the aircraft's other equipment is also interfering with the affected instrument's readings.
Discover the ultimate in relaxed romance with the best casual dating platform! Authentic Ladies ...
Exemplary Сasual Dating - Verified Damsels
