Results 11 to 20 of 65
October 11th, 2020 07:14 PM #11
Some fix it suggestions from YT: How to fix laptop screen flickering and horizontal lines-1 Simple steps to fix - YouTube
October 11th, 2020 07:14 PM #12
Its either monitor or ribbon cable. I remember there was a 3rd party repair guy whondelievered a warranty service on my work laptop. He arrange a meeting in a library in the US. I watched him repair my laptop in 10 minutes. He knew where the locking tabs were.
In your case it is a hardware issue. Your warranty is 3yrs with hp. When you're back in the USA. Just bring the unit to that shopnor claim warranty online.
October 11th, 2020 07:16 PM #13
- Jun 2005
- 3,769
October 11th, 2020 07:25 PM #14Just have the lcd screen replaced. Dami naman na gumagawa screen replacement.
Sent from my MI MAX 2 using Tapatalk
October 11th, 2020 07:30 PM #15
Thanks. This is weird. Bakit 2018 lumabas when I bought the laptop brand new in Sep.2019, unless nanloko yung seller? Pero malabo refurbished kasi nakalagay naman yun sa Amazon and it came with a box and all the stickers look new, pati amoy.
Tumaas presyo ng mga laptop!?!? I looked at the links from my other laptop choices, at lahat tumaas din same specs naman
Sent from my SM-N960F using TapatalkLast edited by _Cathy_; October 11th, 2020 at 07:40 PM.
October 11th, 2020 11:22 PM #16
When you go to the states, you can dispute the warranty. You just need to produce the proof-of purchase. It being bought from Amazon, that shouldn't be difficult to do.
HP PCs, Printers - How to Submit a Dispute to Validate Your Warranty | HP(R) Customer Support
October 12th, 2020 06:05 PM #17
Thanks, I'll try this
2 years lang
I did sa TV ko, and it has no line pag sa TV ko
I can live with this line naman. I am disappointed lang that it happened to a 1 yr old laptop. Sana lang talaga wag lumala
I do hope it does not get worse in case I won't be able to go back before September
October 12th, 2020 06:09 PM #18
- Nov 2019
- 960
October 12th, 2020 07:18 PM #19It's either the ribbon cable or LCD.
If you try to press on some part in the LCD where the line might disappear, probably replacing cable will fix the issue.
If cable issue, usually lower part ng LCD nakalagay, dyan mo i press to check if there is a change in the display.
But if the line defect won't change even pressing on other parts in LCD, then it is an LCD issue.
Replacing LCD HW is the only fix for that.
September 21st, 2021 11:52 AM #20
Bad trip! I woke up to see a second line on my monitor. This is a 24 month old laptop HP never again. I guess I have to start canvassing a new laptop. I could live with the first line on the task bar area but the second line is annoying
Production of the next gen Kicks confirmed .......
2025 Nissan Kicks
