Results 11 to 17 of 17
November 5th, 2007 05:19 PM #11
Cool! Ubuntu is amazing. By the way, did you create a new partition specifically for the linux distro? If you are going to reinstall, I suggest you format the entire HDD and create 2 partitions, one for XP and the other for Ubuntu, so you don't run into any problems in the future.
November 5th, 2007 09:37 PM #12
mr incredible, yes got two partitions... 1 for the existing Italian XP and 1 for the UBUNTU... fortunately when I got the laptop the 80GB HDD is already partitioned into two. Problem ko with the UBUNTU right now is that I can not find the correct WiFi driver for the the PC.
Okay back to topic... so I got this pirated copy of Win XP PRO, loaded in the disc tray, and then it automatically started the XP PRO installer, but when I selected WinXP installation, there is this Italian message popped up somehow saying that the disc am trying to use for the XP installation is not the disc used to install the existing XP. Pati yon na detect niya. By the way I have to copy the popup message and translate it somewhere in the web.
Anyway, I've searched the web, and everybody is claiming that is not possible to convert a localized Win XP to english, aside from starting from a clean install. It is only possible to convert an existing english XP to localized XP (LIP or MUI).
If I have to do a clean install, sayang lang 'yong mga existing applications that acer already installed in this laptop.
November 6th, 2007 03:48 PM #13
most of the pirated winxp are corporate edition media. Your serial key is an OEM, better get OEM media for your installation and try to use your OEM license key written in the bottom of your laptop.
November 7th, 2007 04:19 AM #14
This may be a long shot but why don't you try calling or bringing the laptop to the acer service center and ask if anything can be done about your dilemma.
here's the contact info:
Acer Service Center
1651 Paz Guazon St.,
Paco, Manila
Tel No. (632) 564-1841
Fax No. (632) 563-9317
email: service*acer.com.ph
November 8th, 2007 09:14 AM #15
Already did sir, and since the lappy don't have international warranty they are going to charge me for the WinXP OS, plus the other Acer SW Apps, plus the service charge, estimate given is around 10k pesos.
So right now, did an install WinXP (pirated) from a clean start, downloaded all the drivers from Acer support site... now the lappy is back to to life with english Win XP, pirated nga lang... hehehe I've connected to the network overnite, but so far microsoft has not detected it... okay pa..
BANNED BANNED BANNED
- 3,790
November 8th, 2007 12:40 PM #16eto naman ang solution ko dyan sa pWinXP install para hindi madetect kung geniune or not - http://tsikot.yehey.com/forums/showp...0&postcount=16
November 10th, 2007 05:08 AM #17
Good to hear that everything's ok with your new(ly acquired) laptop.
Regarding your use of a pirated XP installer, just as long as you used the same version as the previously installed one (home or xp), and used the serial indicated at the bottom of the laptop, then everything should be fine.
Burberry Men Leather Jacket oskarjacket
Verifpro - paypal, ebay, banks, crypto, docs and...
