Results 21 to 27 of 27
November 26th, 2008 02:39 PM #22
Password Protect USB 3.6.2
Protecting folders on external and removable drives and access your folders from any computer your drive is plugged into.
If you have several computers and your removable drive travels between them, install Password Protect USB right on your removable drive.
Password Protect USB 3.6.2You will be able to protect/unprotect folders on multiple computers your drive is connected to. However, you will need to get just a single license as you install the program on a single external drive, not all these computers.
Do folders retain protection when the external drive is disconnected?Yes, they do. To open the folder, you need to connect your drive to a PC, run Password Protect USB from the installation directory on your external drive, select the folder and enter the password.
What drives are supported?
Password Protect USB is fully compatible with all types of external and removable drives (including USB drives):
SB flash drives, USB pen drives
Removable drives (ZIP-drives)
USB External hard drives
USB External removable drives
...it says you have to install the soft to the removable usb drive.
December 1st, 2008 12:59 AM #23
Download ka nalang ng software and save mo file sa flashdrive. Ganon kasi ginawa ko.
December 1st, 2008 10:43 PM #24
Ang ginamit ko nalang is the U3 Launchpad of Sandisk. Fortunately, Sandisk din ang flashdrive ko. Everytime I insert the flashdrive to the PC, it will load the U3 Launchpad (but doesn't install itself to the host PC), then it will prompt for the password. Very neat.
December 2nd, 2008 07:54 PM #25
Ayus... di yata mag work ung U3 kapag hindi SanDisk yung flash disk mo.
December 3rd, 2008 07:51 AM #26
- Nov 2010
- 1
November 22nd, 2010 01:03 PM #27Eto mga ka.tsikot
No admin rights required na encryption. On the go, on any pc! wow.
http://www.rohos.com/products/rohos-mini-drive/
Automatic po Sir
