Results 31 to 40 of 52
December 31st, 2006 02:04 AM #31
December 31st, 2006 02:15 AM #32
usually, kapag ganyan ang modem na binibigay ng PLDT, naka NGN na ang phone line na may DSL. hindi na kelangan ng username and password, auto DHCP lang ang connection type.
ang setup ko now is from the router port of the PL-DSL1 to the WAN port of my DLink wired router. then from DLink router port to the router port of my Linksys wireless router para maging wifi.
hindi ko talaga maintindihan at maisip kung bakit walang internet kapag i-connect ko directly sa WAN port ng Linksys wireless router ko from the modem-router of PLDT, pero sa DLink wired router e pwede naman.
December 31st, 2006 02:28 AM #34
hallelujah.. i'm setting-up the router. i'm on step#8. unable to connect daw pero naka-post ako dito. sinunod kop lang advice ni mikmik316 na iconnect sa regular port ng linksys router at di sa internet port.
what should i do now. do i need to exit the set-up. pag click ko kasi ng next,check lang sya ng connection, then unable to connect to the router naman sinasabi.. paulit-ulit lang..
December 31st, 2006 02:39 AM #35
checked the bandwidth... pldt plan 999, i'm getting 497kbps on the main PC while 453kbps on the laptop..
December 31st, 2006 02:43 AM #36
hindi mo pwede gamitin ang setup wizard ng linksys if hindi sa WAN port nakakabit internet mo. dyan kasi naghahanap ng internet connection ang setup wizard at hindi sa router side.
December 31st, 2006 03:32 AM #37
January 4th, 2007 01:52 AM #38
here's the set-up..
PC1 - xp pro sp2
PC2 (laptop) - xp home
Pldt DSL plan 999
here's the problem. pag yung PC1 & DSL modem lang ang naka-on, okay ang dsl connection at walang time-out or slowdown. pero once ginamit na yung PC2 at linksys for internet, within 10-15 minutes ay unti-unti na mawawalan ng connection yung PC1 hanggang di na makabrowse. pero pag disconnect ng PC2 at ini-off ang Linksys, kelangan pa irestart yung PL-DSL1 modem para bumalik yung connection ng PC1..
what seems to be the problem..
January 4th, 2007 12:09 PM #39
- 10,620
January 4th, 2007 12:24 PM #40masalimuot pala ang pldt dsl...yung smart bro from the antenna to the small thing (that needs to be plugged) tapos to the PC or Router
Choosing one would depend on your driving and parking conditions. Do you have your own garage =...
MG4 EV Standard vs BYD Atto 3 Dynamic vs Toyota...
