Results 21 to 30 of 30
May 2nd, 2009 03:56 AM #21
*shadow - whoah.. sorry to hear that if ever na binlock man nila atalaga connection mo for a router config..
wala naman ako problem with a router connected to smart bro. Dlink router gamit ko pambahay lang naman. okey naman
- May 2008
- 2
June 22nd, 2009 11:45 PM #22Anong sinabi mo sa NTC? Pareho na din tayo ng problema at nabwibwisit na din ako dito sa Smart. Nun Saturday afternoon nagsimula na yun problema, nun tumawag kami sa Smart ang sabi "we are doing enhancements to serve you better" pero nun gabi hindi na nakaka-connect ang router. Nasa phone na kami ngayon at walang sumasagot, puro music lang. Nakakainis na talaga.
June 23rd, 2009 12:38 PM #25
Sir shadow, anu email ng NTC? di ko makita sa website nila eh.
OT
irereklamo ko din pldt dsl ko. mas mabilis pa upstream ko sa downstream. 1mbps dapat binabato nila sa downstream but im only getting .25mbps. upstream ko .47mbps. then tumawag ko sa customer service i should get at least 60% daw ng 1mbps.
Tsikot Member Rank 4
- Jan 2007
- 2,326
June 24th, 2009 08:14 AM #26Shadow,
Di ba USB ang smartbro? Paano mo kinabit ang wireless router? Thru the LAN card of your PC? Sa akin kasi ayaw mag work yung ganun eh.
June 24th, 2009 09:05 AM #27
June 24th, 2009 02:35 PM #29
since we are talking about dsl, would just like to know your opinions/comments/advice. recently i just bought hp touch laptop with a free globe tattoo prepaid and im using this tattoo here in batangas (my gf is using the hp touch, and im using the old macbook OS X with this tattoo). the problem is, nabwi-bwisit nko dito sa globe tattoo prepaid. minsan ok cya gamitin, minsan bad trip!! ayaw mag-connect s net. now im planning to have a wired access, either a pldt dsl or a globe wired. any advice between pldt dsl and globe wired? tnx a lot!
June 25th, 2009 02:50 PM #30
You can still share your net access by Activating ICS (Internet Connection Sharing) in the PC that is connected to the USB wireless modem.
Just assign the said PC's IP address as the default gateway of the other computers that will share the internet access.
Downside: you need to keep the "gateway" PC running while the other PC's need net access.
