Results 21 to 30 of 33
January 14th, 2010 12:53 PM #21
I used a USB keyboard, the 'keyboard error' is gone but still unable to load Windows (log-on screen).
I set the BIOS to boot on CD-ROM but computer still cannot boot thru CD ...
Is it possible to connect my HDD to a different computer and perform a chkdsk /r?? Will it work?
January 14th, 2010 01:03 PM #22
January 14th, 2010 04:56 PM #23
The symptoms my previous pc showed before the motherboard died was:
It started shutting down spontaneously. When I power up the pc, it'll post. But as soon as Windows or Linux tried to load, the power shut down immediately. I tried the PSU on a different pc and it worked fine.
I tried booting from a Windows install cd or a Linux Live CD. The same thing. Immediate shutdown. It wasn't the PSU. It wasn't the ram. It definitely wasn't the video card.
Upon close examination of the motherboard, I saw something similar to this:
http://en.wikipedia.org/wiki/File:Bu...yeh_caps_2.jpg
Bulging and/or leaking capacitors.
As it got worse, the power button wouldn't even work after shutdown. The activity light simply blinked. Pulling the plug and putting it back in allowed the pc to power up again. But, it just shutdown again as soon as an OS tried to load.
If you have similar capacitors on your motherboard especially behind the cpu, kiss your motherboard goodbye unless you can get it fixed for cheap there.
Here, it's not worth it. It's cheaper to buy a replacement motherboard, one with solid state capacitors.Last edited by Jun aka Pekto; January 14th, 2010 at 05:05 PM.
January 14th, 2010 05:06 PM #24
I have had problems with bulging/leaking capacitors as early as the year 2000 when I purchased additional PCs for my Internet Cafe business then. The units didn't last a year before having the above mentioned problems.
At least I was able to claim warranty replacement motherboards (different model to avoid the same fate of the original boards).
January 14th, 2010 05:53 PM #25
Pekto's right, you should look for bulging capacitors, not just leaking ones. And trying the PSU on other PC's is a good first step.
[SIZE=1]3618[/SIZE]
January 15th, 2010 02:36 AM #26
1.check if there is blooted capacitor
2. PSU yan dahil nag over heat na siya sa tagal ba naman ng open mo bumigay at hindi na nag run ang fan nya ganoon din sa akin noon change ako
try mong humiram sa mga friend mo ng psu
January 23rd, 2010 06:37 PM #27
Update:
My home PC is back to normal. RAM module problem caused it. I have it replaced (still under warranty) pero ganun pa rin. I did a clean install of my OS. No choice. I lost some of my data /files on my drive. First time ko mag-reformat/reinstall ng windows (DIY). Good thing I found a guide from BlackViper.
Also the 100% CPU usage problem is gone. I also checked my mobo's capacitors but still good.
January 26th, 2010 02:03 PM #28
an update: this is the thing that happened to me. palit na ako ng MOBO yesterday. the problem, medyo luma na yung mobo, so i have to replace the processor as well as the RAM as well.
eto na ngayon, gamit ko na.
ang tanong:
- i have a new DASD too, i am thinking of using it as SATA.
- the new MOBO only comes with one IDE slot, i am reserving it for the DVD drive and a slave DASD.
- the problem, walang SATA power connector yung PS ko. May mga adaptor bang nabibili dito so i can still use my existing PS (which is ok pa), or do i need to also change my PS?
thanks.
January 26th, 2010 02:51 PM #30
IIRC they're with AVID. The reported numbers in the TG article are from CAMPI.
Car Sales Data (2024)
