Results 31 to 39 of 39
June 1st, 2007 02:25 PM #31
I suggest you use the msconfig or regedit.
-Go to START button and run "msconfig"
-Go to startup tab and remove the run apps that you think is doubtful.
-Run a multiple Os in your system so that when one OS fails, you can still diagnose your pc or run Anti-virus software that's not infected.
-Backup all your data in a DVD or extra HD.
-Try to delete all the cookies in your temp directory in your Documents & Settings folder.
-Use a more stable and safe browsers like Firefox or Netscape 8.1.
-Install Norton Anti-virus software or its equivalent. Update your virus DAt file every as often as possible. If NAV can't delete the virus file BUT can identify it's location, all you need is copy the path(location) of the virus file, then use the "regedit" command and search the virus file in your registry. After the regedit search found the location of the file in your registry, you can delete the registry of the virus.Last edited by mikaztro; June 1st, 2007 at 02:32 PM.
- Mar 2007
- 224
June 1st, 2007 02:37 PM #32Nasolve ko na spyware na to>
try this from Tipidpc.com member
actually 2 files yan isang Autorun.inf at exiplorer. ngkaroon ung pc ko dahil ginamit ng misis ko ung usb niya sa netopia hayun meron na ako... try mo hijack this..
pero ako mano-mano.
ganito gawin mo..
open mo ung task manager mo [ctrl-alt-del] tapos punta ka sa Processess, hanapin mo ung exiplorer.exe, pag meron ka nakita, END Process mo.. tapos punta ka sa Folder Options-->choose Show Hidden FIles, tapos unchecked mo ung 2 options pa sa baba nun - Click mo OK..
check mo ung mga HDD mo kung meron mang Autorun.inf at exiplorer pag meron delete mo na..
then open regedit
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon] then hanap mo eto
"LegalNoticeCaption"=""
"LegalNoticeText"=""
delete mo lang ung value, wag ung mismong registry data, then
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\Curr entVersion\Run]
hanapin mo kung nakalist ung exiplorer.exe then delete pag meron
haba ng method ko, pero try mo HIJACK THIS mas mabilis
June 1st, 2007 04:49 PM #33
- Jun 2007
- 1
June 10th, 2007 02:53 AM #34* Rudyphoto
as in po ba nawala na ung mga hidden files nung ginawa nyo yan? about dun po sa last part . ung value po ng NTWindow is "exiplorer.exe" tatanggalin ko lang po ba ung value or pati ung NTWindow? sry po newb lang me salamat po
- Mar 2007
- 224
June 10th, 2007 11:17 AM #35
- Mar 2007
- 224
June 10th, 2007 11:18 AM #36any software that can prevent this kind of spyware? kapag yung mga staff ko ang gumagamit ng pc, napapasukan pa din eh. TIA.
June 10th, 2007 02:14 PM #37
June 10th, 2007 08:42 PM #38
Stay away from warez, P2P, pr0n, some gaming, and other ad-crazy sites. I could've sworn I've even picked one or two spyware from this site (plus a number of other sites from RP) although I can't remember what or when. I do remember having a suspicious certificate error from one of the threads (Hot Chicks?) at the Pitstop Subforum. I saved a screencap for future reference.
Not sure what it is. It may be nothing. But, seeing stuff like this makes me quite wary.
Most browsers nowadays should have effective ad-blockers. For realtime spyware protection, I do agree with using Windows Defender. It's free and it works well. There are of course, the freebie spyware removal apps or even retail Internet Security software.
Add: if you must have an unmonitored internet pc, make sure it's a dedicated pc not connected to the rest of the networkLast edited by Jun aka Pekto; June 10th, 2007 at 08:58 PM.
- Jun 2007
- 1
June 18th, 2007 12:20 PM #39mga tol n dale n nyo po b nyo un
PROMISE??
i am still waiting for strawberry from bagiuo
kung di pa
eto po sgot
download kyo ng SOPHOS anti virus
khit un free ok lang kaya nya linisin un
tapos
REGEDIT kyo
punta kayo s
HKEY_LOCAL_MAHCINE
SOFTWARE
Microsoft
Windows NT
Winlogon
dun makikita nyo un script
burahin nyo lang
pang ktapos nyo clena ng SOPHOS anti virus
kasi di nya kaya tanggaling un script
hope na na tanggal nyo yan pa cute n VIRUS
Denali Lights, Dial Dim, & Soundbomb Review—Is It Worth The Premium? | Behind A Desk MotoDeal
Auxiliary Driving|Fog Lamps
