Page 5 of 6 FirstFirst 123456 LastLast
Results 41 to 50 of 53
    Aug 2009
    #41
    Quote Originally Posted by ecneret View Post
    sorry sa OT mods.
    anyways, about don sa tanong mo, LCD tv ba dala nya o yung may picture tube pa? kasi ang alam ko yung mga lumang tv lang ang kino-convert. pero baka mali din ang pagkakaalam ko.
    Samsung LED 32"
    Oct 2011
    #42
    mura na din naman ngayon ang branded na LCD LED Plasma LIKE LG and Samsung.... meron ako nakita sa sulit nasa 38K lang 51 Inch na na samsung plasma.... yung 42 na LG LCD if i remember correctly nasa 28k-32k lang HD NA din mga yan.... LG na 42" 3D na plasma 31.5K lang.... BRANDED nalang po kayo para sigurado.....
    pag dating po sa pag basa ng video format LG po ata ang may pinakamadaming nababasang format.... pero mga sir... bumile nalang kayo ng media player mura din lang yung kaiboer meron nasa more than 2K lang.... sa sulit din po meron....
    tumpak. mura na din basta't older model na. ang mahal sa samsung or sony ung mga bagong labas at series na LED na 55" pataas.
    Sep 2005
    #43
    eto Promac 24" LED HD TV for 8,990
    Promac LED TV Discount
    Oct 2011
    #44
    Which is better? LCD, LED or Plasma TV?
    We have all heard the stories, from years back about how Plasma TV’s suffer screen burn and that LCD TVs have problems with fast moving object and sure enough, at the time these point were in some cases true.
    No, a few years later technology has caught up and those problems are a thing of the past, the unfortunate thing is that it leaves the consumer with more choice. Whilst this would normally be good news, it does cause a problem if you don’t fully understand the differences between the 3 competing technologies, then it is hard to make the best choice on your next purchase.
    The quick and simple answer: LCD is the market leader, and it has, over the last few years enjoyed being the major winner, at least in sizes up to 37″ to 40″. (of course, plasma televisions are perfectly good and in fact have some excellent reasons for purchase, which we explain a bit later.)
    Now however, with the latest in TV technology to hit the arena, the LED TV, an extremely thin TV with bright and vivid colors, adds even more choice to the consumer and by the time you have spent 10 minutes reading this simple guide you will better understand the differences, pros and cons of all 3.
    Reason for the simple Answer: The LCD TV is the market leader because in relation to screen size it is the cheapest technology; almost all manufacturers have 1080p LCD models in their line-up which helps keep prices down. The High Resolution, 1080p LCD TV sets will cost more than 720p LCD TVs, or even a plasma of similar dimensions, but both however will be cheaper than the newer LED backlit TVs of a similar size.
    So, what is the difference between the 3 types; LED, Plasma and LCD? Simply, it’s the method of producing the “light” emitted by the screen. With LCD TVs using compact fluorescent tubes, strip lights; very small ones and the LED TV using high power Light Emitting Diodes, more energy efficient but more expensive.
    Plasma TV work in a completely different way , lighting each pixel individually, with each then producing its own light, which we think gives not only much better contrast ratios but also a deeper perception of color. The slightly higher power usage that this type of TV uses has caused it to lose favour over the LCD TV, however, if you really want size, then the Plasma TV is the best bet, especially on sizes over 42 inches.
    If you must keep up with the neighbors then the LED is the number 1 in the newness stakes, with super thin TVs, in some cases well under an inch. Unfortunately, like everything else in the technology game it does come at a cost, with an increase in price over a similarly sized LCD or Plasma TV. About 30-40% more in fact.
    Each have their own pros and cons, LCD vs Plasma vs LED:
    Price, Picture Quality, and Energy Efficiency.
    Price: Regardless of which point you look at it from the LCD TV wins on price on any Flat Screen TV up to 40″ in size and from that point its the bigger brother, the Plasma TV. LED being in its infancy comes with a higher price. Specifications are similar across the range.
    Picture Quality: LCD TVs have improved a thousand fold in the last few years, with fast frame rates and great contrast ratios, the picture quality can be amazing. The LCD is only bettered by the sometimes lifelike pictures displayed by the better branded Plasma TVs, with Pioneer a particular top choice. The LED set uses almost exactly the same technology as its stablemate, the LCD and because of this, it produces much the same in the way of picture, with a slight improvement in black levels.
    Contrast Ratio: This is the difference between the Lighter and Darker areas of any picture. Plasma TVs have contrast ratios that easily surpass that of the LCD or LED TV, thanks to the individually lit cells but new LCD TVs are beginning to catch up, with the newest LCD sets from LG, Sony and Samsung almost equalling the Plasma in terms of contrast ratio. But not quite. LED TVs again, LCD TVs with a LEDs for back lights, come again a little bit closer to the depths of contrast you see in most plasma TVs and soon they will be the same. But, as of this moment the Plasma TV is still the leader.
    Resolution: What is 1080p? It’s High Definition, you will also hear other resolutions mentioned; 720p and 1080i, abut 1080p is the highest resolution you’ll see in stores or online. It is purely the number of lines of information used to construct the picture you see. The higher the number, the better the picture; Akin to digital camera resolutions.
    Refresh Rate and Response Time: Remember the stories from 5 years ago, or just watching a football skip across the screen, that’s refresh rate; and the response time is the time taken for the TV to change from 1 frame to the next.
    Most LCD TVs manage to output around 60fps, frames per second, this is the same as used for HDTV. however some manufacturers offer sets with higher frame rates than this, 120Hz, 240Hz and even 600Hz, for fast moving game play or sports on the big screen TV this can be an excellent feature.
    Image Processor: The humble TV is really just a computer, a computer that has to decipher a watchable TV image from a signal containing sometimes hundreds of other TV signals, done by the tuner; and once it has done this the TV then has to construct the video stream and display it for you to watch, this is called image processing. So, on a 1080p TV the image processing is harder than on say a 720p set. All 3 sets utilise the same methods of video processing, with only the software and components changing, what we would say is that branded makes spend more on their processing hardware and software than the budget makers. For obvious reasons.
    Price: Price is the biggest market fact, no beating about the bush, and we’ve said it twice already.
    Up to 40 inches – LCD
    Over 40 inches – Plasma
    LED is 30-40% more expensive, inch for inch.
    Power Consumption: The newest sets based on LED back lighting use the least energy when in use, saving on average 20% over LCD and up to 45% on a Plasma TV which somewhat outweighs the extra additional cost.
    Screen Burn: This is not an issue on any of the 3 different type sets..
    In the End: Which is better, LCD, LED or Plasma? Really that depends on you and what you need from your TV;
    Up to 40″ is the LCD TV, on Price alone.
    from 40″- 42″ it’s either a Plasma or LCD set.
    Over 42″ is the Plasma TV, on Price.
    Source: Which Television is better? LCD, LED or Plasma?
    Oct 2011
    #45
    definitely go for LED dahil ito ay mas modern technology and lower power consumption. pero kapag on budget, pwede na LCD. magaganda na rin ang LCD ngayon. for ultimate contrast ratio definitely go for plasma tv's.
    Sep 2005
    #46
    sa S&R stores mura na din.. yung SAMSUNG LED 40" nila nasa 32T na lang..
    Jan 2008
    #47
    depende pa din sa series ng samsung... meron kami 37 inch series 4 LCD TV.. malinaw naman pero compared dun sa 32 inch series 5 LED na enhance pa nya yung picture compared sa series 4...
    madami kasi ang akala nila eh pare parehas lahat ng LCD at LED... depende po yan sa series na binibili nyo...
    Sep 2005
    #48
    wala nang series 4 na LED ngayon sir sa Samsung.. lahat series 5 pataas na..
    Oct 2011
    #49
    ung iba meron buy 1 take 1 lcd tv promo.
    Jun 2008
    #50
    mga bros ok ba ang brand na akai para sa LED tv?
Generic LCD/LED TV, are they okay?
