Results 31 to 40 of 52
August 27th, 2006 10:49 PM #31
PCM is very hard to find locally, best bet is under a new heatsink. I do have a bunch of them, you can have some but I don't live very near your place...
If it's too much trouble grease will do if you're just a "regular PC user"...
- Aug 2004
- 243
August 27th, 2006 11:41 PM #32also baka d naman cpu heat ang nag cause ng crash sa pc but hdd heat,if you are using 7200rpm then maybe you can install hdd fan.
if you really want cool cpu then install a water based cooling stuff just like during my college days when i used to overclock amd processor hehehe.
Dati DIY lang yang water based radiator cooling fan pero i think you can have it now for roughly 3k. im not really updated when it comes to this because im just content with intel based processor which does not require too much tweaking.
another cheap suggestion .. tuktuk mo lang electric fan sa bukas na cpu hehehe.
- Aug 2004
- 243
August 27th, 2006 11:43 PM #33also you can consider aluminum based cpu case like the enlight series but then that is roughly 5k for their entry level if i am correct.
August 28th, 2006 12:12 AM #34
August 28th, 2006 07:57 AM #35
August 28th, 2006 08:07 AM #36
as much as possible for my servers i stick to maxtor 5400 rpms.....i had experience w/seagates, pero my maxtors held way better than seagate,specifically barracuda 7200 rpm..madali magkabad-sector at HDD crash...40gig lang server ko...and its hard to find 5400 rpm HD these days, brand-new....lalo na 80 gig up!
maxtor ang choice ko lang,e..sa MB, asus/ecs/redfox...
FrankDrebin GuestAugust 28th, 2006 11:39 AM #37
Solved mine using a full copper heatsink, TT smart fan, and a well ventilated casing.
Kami dati naglalagay ng chain lock ng motor or bike. Iba nakita ko literal na kadena at padlock.
