Page 6 of 9 FirstFirst ... 23456789 LastLast
Results 51 to 60 of 88
    Mar 2004
    #51
    Can Dahua connect and use WiFi cameras above 1080p? ...
    #52
    ^ Pwede. A typical 1080p is around 2MP. Most of my cam were replaced by 4MP.
    Its still best to use that PoE NVR for easiest deployment, also more reliable if properly installed.
    Jan 2016
    #53
    Planning to buy this, any advice from those who already have this? It also requires 6 pcs 18650 batteries, which I found out ranges from 100-200 pesos each, any advice on this also. Thanks img_20220403_210740.jpgimg_20220403_211352.jpgimg_20220403_211425.jpg
    #54
    Makikibalita din ako regarding this. Need to place a camera sa maliit na bodega across the street, sana abot wifi signal.
    Signature
    Jan 2016
    #55
    I already ordered 1 this morning, now my problem is where to buy good 18650 batteries. Anyone know a reputable seller in Shopee or Lazada? And what's a good capacity for IP cam use? I read that for high drain devices it's best to buy the lower capacity of 2400 mAh.
    Dec 2009
    #56
    ^its not just an IPcam its a movable cam (pan and tilt)..the motor will drain the batteries quick if you move the camera view a lot
    during night time when theres no chance the batteries will get charged the IR lights will drain it
    Jan 2016
    #57
    I hope not, spent almost 4k for this tapos ganun lang hehe. Anyway it arrived today, I'm charging the battery pack today and will install it tomorrow.
    Jan 2016
    #58
    Bad trip, hirap configure nung device, try ko ulit tom hopefully with the help of the supplier.
    Dec 2009
    #59
    ^let us know if it has an AI feature which follows the moving human subject automatically..that will drain the battery kasi
    if thats the case just power up the device with a DC adaptor
    #60
    Ganito yung balak ko bilhin. Yung may homebase, dyan ma record yung videos and images. Then yung camera eh wireless both power and internet, siguro twice a year lang mag charge depende kung ilang beses mag record. Pag may ba detect lang na human, saka mag record.img_20220411_160123.jpg
CCTV camera, monitor & DVR
