Results 11 to 17 of 17
October 23rd, 2007 11:54 PM #11
nurse on wheels
- Dec 2006
- 392
October 24th, 2007 07:25 AM #12IIRC, if you use sticks of varying speeds, the low speed is the one that is utilized by all, so if you use 2 sticks of 333 and 2 sticks of 400, the 333 speed is the one used. but yes, they will run together, though not as well as if all used the same speed.
October 24th, 2007 09:32 AM #13
boybi... pwede yan... I had that kind of MOBO before. AFAIR - naka boot na ako dati using 3 sticks of memory.
although mas ok na bumili ka ng 2 512MB RAM na same brand & speed nung existing mo para ma utilize mo yung dual channel capability.
October 25th, 2007 09:12 AM #14
October 25th, 2007 09:20 AM #15
nope... hindi na dual channel... dapat either 2 or 4 ang memory stick na nakalagay para dual channel.
and dapat same brand para dual channel (according sa manual).
October 25th, 2007 03:09 PM #16
Hindi din pala naka dual channel yung existing 2 sticks of 512mb ram ko so bumili na ako ng 1 1gb ram. Gumana naman.
5% lang ba talaga ang improvement ng dual channel sa single channel?
October 25th, 2007 03:11 PM #17
It should be able to take 3 sticks of ram except the default mode will be single channel. I also have a K8N (non-SLI). I have to find the manual, though.
Thank you!
