Results 21 to 30 of 31
July 16th, 2013 06:36 PM #21
It might but the video GPU would be built-in on the motherboard to fit the form factor so don't expect very good GPUs unless you are willing to pay an arm and leg for an extreme gamer level motherboard with built-in gpu.
It is possible to fit an entry to advance level GPU into a ATX micro PC casing and bracket that behind a large monitor. It won't look cutting edge but it would be "clean" since most of the wires would be to the rear of the monitor.
July 16th, 2013 06:39 PM #22
How about going WIRELESS? You can locate the PC CPU under the desk and hidden from view... or even in a nearby cabinet. Then using a wireless mouse and keyboard, you can have control. Sound can be wired around the room. Using a wireless monitor adapter, you can transmit video signals from the CPU to the monitor. So in the end, the only cable left will be the power cable to the monitor.
July 16th, 2013 07:19 PM #23
I'll give this a thought. How reliable are the wireless monitor adapters?
I'm currently using Logitech wireless keyboard and mouse. If I place the USB transmitter/receiver at the back of the PC (my PC is under the table), the keyboard is sometimes not responsive. I have to use a USB extension cord so the transmitter will be on top of the table.Signature
July 17th, 2013 10:46 AM #24
don't think so.
pc games rely on the processor, RAM and video card.
had assembled something two months ago to upgrade our 6 year old unit.
CPU = AMD A800 Processor (costs around 5k)
Mobo = Asus (costs around 4k)
RAM = 8 GB
Video Card = Asus Nvidia 2GB
Sound Card = Creative Sound Blaster (costs around 1,500)
Gaming Keyboard = A4Tech (costs around 900 pesos)
Gaming Mouse = A4Tech (costs around 500 pesos)
PSU = 600 w, costs around 900 pesos
Did not upgrade the harddisk (2 x 500 GB)
Also did not upgrade the casing
July 17th, 2013 11:14 AM #25
I have seen them around but I have not used them myself. So I cannot give you an opinion on them. And they differ in screen solution quality. So something you might find okay at work may not be adequate for home theater use.
It is all the matter of placing the USB receiver in a location that it can detect the signals better. It might be the front or rear of the case that might give the best reception... or use an extension USB cable to located the USB receiver in a better place. I do this for our office PCs using WIFI to connect to our network. I use USB wifi dongles with USB extension cords so I can re-locate the receivers at a better location for a more stronger faster signal from the central WiFi router.
In your case, you might just need to place the receiver under the desk so it would be out of sight yet close enough to receive strong signals. BTW, I assume your wireless keyboard is using RF and not IR?Last edited by ghosthunter; July 17th, 2013 at 11:18 AM.
July 18th, 2013 11:27 AM #26
I got the HP Envy 23, and just realized that it doesn't support dual monitors since it doesn't have a video out. Searched the net and found out there's a USB adaptor for a second monitor. I hope it's available here.
Signature
July 19th, 2013 01:31 AM #29
July 19th, 2013 01:32 AM #30
Dito sa suking computer store sa probinsya namin. i5 nga lang daw available dito sa Phils.
Signature
doubledouble.
2024 Manila International Auto Show APRIL 4-7,...
