Results 11 to 17 of 17
February 21st, 2014 12:28 AM #11
meron pa naman po...
i mean relative ung term na ikakaganda..
dual core pa din yan...
now kung paano ito gaganda is up to you,,,
[ROOT] Framaroot, a one-click apk to root some devices - xda-developers
ito unp://forum.xdg rooting procedure niya
una root lang tanggalin ung mga unnecessary apps...
then it up to you..
kung mag veventure ka sa custom roms,which i suggest you do,di ako makakapgrecommend ng specific kasi iab iba panlasa natin e..
ito din links andito na din ung files..
http://forum.xda-developers.com/show....php?t=2359306
Step 1: Download and unzip the three attached files.
Step 2: To install the drivers for the computer, had to reboot the computer (Win8 64x) and disable driver signing. Then turn off the phone, connect to the computer, and run the InstallDriver.exe. After the driver installation is complete, disconnect the phone. The phone only makes the pre-loader interface available for a couple seconds when the USB cable is first plugged into the computer.
Step 3: Open the folder with the flash tool, and run Flash_tool.exe. Click the scatter-loading button and select "MT6577_Android_scatter_emmc.txt" from the recovery folder you downloaded. The recovery check box should automatically be populated with the TWRP.img file.
Step 4: Click download button and select "yes" to ignore the dialogue box. The flash software will now wait till it sees the MT6577 interface from the phone. With the phone off. Plug the USB cable into the phone and then into the computer. The flashing software will automatically load the recovery image to the phone. The flash-tool will show the power status bar red to yellow then wait for the message "OK" green is successful, then disconnect the phone, the TWRP recovery has been flashed. If the flash does not detect the phone when you plug it in, check your driver installation from step 2.
Step 5: Access recovery mode by pressing volume up + home + power key until the phone vibrates or it boots into recovery mode, then let go. This time open Team Win Recovery. You now have TW recovery and you can now root your device. (Make android backup first before rooting you phone)
Rooting Lenovo Ideaphone A390
After boot in recovery it will ask you to install superSU just drag/swipe to install. After you reboot the phone, you will have to have internet access to download the GUI. You can download the GUI from the play store, or download a zip which you can flash from recovery.
You are now rooted!
Good Luck
http://youtu.be/lrWQkyOv18E
February 21st, 2014 06:41 AM #12
Daming bloatware ng ibaibang android devices. Gusto ko din gawin ito kaso tinatamad na ako at nakuntento na sa basic stuff ng phone. Ang gusto ko lang sa CFW at Root is meron mga apps na kahit manakaw phone mo di nila mabubura at nakaimbed padin sa unit kahit anong factory reset at bago maaccess ung pang palit ng FW need mo maiunlock. In short madedetect mo padin via findmymobile app ng samsung.
Mas okay android ngayon dati pasakit maginstall ng ng CFW during the windows mobile days. Hahahha.
Pashare naman din ng info kung ano pinkaclean na software para sa s3 and s4 at inextend nindamsung ng 6 months warranty ng s3 ko kaya pagkatapos mag CFW na ako.
Sa katangahan ko nga pala naiupgrade ko ng wala sa oras s3 and s4 ko sa 4.3 bago ko maiunlock dahil may bug ung 4.1.2 at 4.2.2 na jelly bean at via code lang sa keypad pwedeng maalis factory unlock ng phone.
Kaya sa mga naka s3 at s4 na hindi pa naguupdate ng firmware wag niyo muna iupdate sa jellybean 4.3, iunlock niyo muna at wala pang solusyon sa 4.3.
Posted via Tsikot Mobile AppLast edited by brainmafia_310; February 21st, 2014 at 06:46 AM.
February 21st, 2014 07:17 AM #13
as far as clean is concerned,
if you are currently satisfied sa performance or atleast functionality ng phone,and really don't mind ung touchwiz ui,
stock rom pa din,rooted,manually remove all bloatwares,twrp recovery na password protected.
pero medyo model specific sa s3 kasi dahil me kani kaniyang version ang us carriers,pero kung international version pwede na yan..
sa jellybean upgrade,if warranty is not an issue might as well skip to a custom rom already,99 percent of the time fixed na ung bugs ng official update.
http://forum.xda-developers.com/show....php?t=2499904
andyan ung need mo for root and recovery...
pero instead of cwm...i suggest twrp
http://true-android.blogspot.com/201...galaxy-s3.html
(me kitkat rom din dito just in case you will be interested.)
kasi me password protection na inooffer para mawala man,di nila basta basta ma wiwipe ung phone,unless you go thru odin,which in any case is relatively easy..
pero medyo losty cause talga pag lost ang phone.
February 21st, 2014 04:45 PM #14
Do not upgrade your phone to Android Kit Kat 4.4 if you plan to root your note 3. May write issues daw, including downloading t*rrent file to your extSD Card...
[Fix][N9005][ExtSdCard Write Issue][Kitkat 4.4.2][NA6] - Rooted - xda-developersLast edited by Monseratto; February 21st, 2014 at 04:54 PM.
February 21st, 2014 11:52 PM #15
not that nagmamagaling pero i checked on the link...
Since kitkat 4.4.2 was released on the Galaxy Note 3, many users were unable to write files to the External SD Card. Below is a simple fix for rooted users on the Galaxy Note 3 N9005 ( International Snapdragon Variant).
and how i understood it,
sa mga nag upgrade to kitkat na note 3,kung di ka rooted e ma eencouter mo ung said issue
kung rooted ka,ito ung possible fix...
or switching to custom kitkat rom
February 22nd, 2014 12:04 AM #16
April 2nd, 2014 09:04 AM #17
Sana maimplement ng samsung yung security ng iphone.
Sa office kasi namin ung iphone napagtripan ibahin ang login details. So nung naglock, kahit anong factory reset ang hinahanap na username at password is ung sa acvount nf nagtrip. Nakaregister onlinw at hindi pweseng alisin unless otherwise aalisin ng original owner.
