Page 8 of 8 FirstFirst ... 45678
Results 141 to 158 of 158
    Jan 2016
    #141
    Getting this thread up again. Pikon na ako sa waterproof outdoor lamps namin, hindi nagtatagal ang bulb pundi na agad, 1 bulb is 400 pa naman, ung parang starter ang pangkabit. So I'm thinking of replacing all three with waterproof but those with ordinary LED bulb na de roscas na lang. Or I can buy solar na lang, parang parehong nasa 600-800 kesos range lang sila.
    Buhayin ko itong thread. I just had 8kw system grid tie installed last week sa bahay.
    I'm expecting na mabawasan bill ko sa second cycle ng billing for the day consumption then on process na din net metering, just waiting for the CFEI sa cityhall na lumabas.
    Why 8kw system lang? Yun na lang ang pwede according to Meralco. I was originally planning to install 12kw but since gusto ko mag net metering eh hinde na pwede dahil hinde na kaya sa capacity ng transformer ni meralco dahil meron na din 3 kapitbahay na naka net metering.
    Why didn't I went for hybrid with battery, talked with the installer about this and since hinde naman madalas mag blackout so hinde din talaga need plus siyempre mas mataas capital outlay. I'm trying to shorten the ROI as short as possible para pag mabawi ko in 2-2.5y or kahit minimal na lang baka meron ng new tech so pwede na ako mag upgrade agad.
    Meron din pala self consumption ang inverter na 20-30W from grid.
    Feb 2024
    #143
    What do you mean by self consumption?
    Jan 2009
    #144
    Quote Originally Posted by Motortrend View Post
    My guess is parasitic draw.
    Jun 2011
    #145
    Ang explain sa amin, kailangan pa din mag draw sa grid para ma stabilize output ng inverter. Erratic kasi output ng panels.
    Sep 2010
    #146
    Joining in na rin. We recently had solar panels installed also. After discussing with the supplier, he suggested to use 6kw & 20kwh for our batteries. I initially wanted to do net metering, but was able to talk to someone na nag apply din ng net metering. His application has been a year na & wala pa rin daw.
    As far as I understand it, depends din daw kasi sa area. If madami nag net metering sa area mo, baka daw hindi muna magtanggap si Meralco kasi maybe umabot na sa limit ang kaya ng station nila sa inyo. Once they make new ones to accept the excess kuryente from your solar panels, that's when they can accept applications again. Plus I think Meralco would buy your excess at a discounted price? 50% ba? So if you want to have net metering, dapat sobrahan yung panels. So the cost of the excess panels would take a longer time to recoup because of the discounted buying price of Meralco. So he suggested to go with batteries instead para instant ang savings.
    Aside from net metering you might want to check out din Meralco's POP (Peak Off-Peak). Basically mas mahal kuryente during the day up until a certain time at night. Then mas mura kuryente after that till morning. So this would be ideal if wala masyadong tao sa house during the day or if naka solar ka. Mas mabilis daw mag apply nito mga 2 weeks lang. Dapat lang yata same name ng Meralco bill & titulo, otherwise mas matagal lang daw process. Will try to apply for this in the next few months. Here's the link: Peak/Off-Peak | Meralco
    So far the 6kw is sufficent during the day. On a good sunny day, by 1pm, naka full charge na batteries ko. On a cloudy day, sometimes late afternoon na. On a rainy day, minimal lang. Then during the night aside from the usual normal consumption, may naka bukas na dalawang 1.5hp na aircon. Then naubos ang battery mga 10pm -12mn. Nag iwan pala ng 30% ang battery in case mag brownout, may konting reserba.
    So from the avearge of P20k bill namin, naging around mga P10k+ na lang.
    Feb 2024
    #147
    Quote Originally Posted by bxr monkey View Post
    Makes sense. Thanks.
    #148
    i have had a solar set up for almost 1 and a half year na. I applied net metering since it was installed and up to now wala pa rin.
    LGU in Makati is asking for too many paperworks and kailagan ng too many signatories. basically red tape.
    Wala pa dyan yung wait for Meralcos approval. makati LGU pa lang yan.
    Kaya tama yung use of Batteries.
    ako currently looking for a good batteries to add to my solar set up.
    i also plan to add more panels.
    Nov 2019
    #149
    For someone like me na 3.5k-5k yung bill monthly, parang no need pa for me to put-up the solar setup.
    2 lang kasi yung inverter aircon, 1 inverter ref and 2 TVs lang appliances namin.
    Stable din electricity sa lugar namin.
    Nung hindi pa inverter ref at AC namin, umabot talaga sa 8k bill ko.
    At malapit na akong mag decide na magpa solar setup nung time na yun.
    Ito explanation din sa amin yun self consumption niya is to balance and stabilize yun energy from grid and panel.
    Why do you guys think the solar panels allegedly caught fire?
    https://x.com/i/status/2058709176579440946
    This happened daw in Vietnam kaya medyo Malabo iyong mga haka-hakang naka post.
    Feb 2024
    #152
    This happened daw in Vietnam kaya medyo Malabo iyong mga haka-haka.
    Could it be the batteries?
    Jan 2009
    #153
    I can't speak for that incident but solar panel fires are not uncommon. If it has enough voltage and current passing through it and a safety mechanism fails, it can potentially self-combust.
    Search Google for solar panel fires and you'll see.
    So the recent hullabaloo about Meralco wanting stricter solar system certifications is not without merit.
    #154
    enough voltage... enough current... shorted wires... batteries... the usual stuff.
    may not even the solar electricity system itself... maybe something else beside it that is not related to it...
    the solar panels themselves... not likely.
    Sep 2008
    #155
    Solar panel for houses in Australia : Band aid solution to a greater problem, still a young technology, not regulated, if it cheaply manufactured = expect poor quality, need maintenance, additional personal time to manage, not technology to recycle the panle/not viable, roi is 7 years kahit meron government financial support, the Sun us free, but not equipment : Hence, hinde ako nagpakabit
    Feb 2014
    #156
    if there's damage to the panel and there's high series voltage (lots of panels in series)... possible arcing, heat, fire
    #157
    In the near future, darating na sa point na need pang humingi ng permits mula sa meralco para lang sa mga gustong magpa-install ng mga solar panels. Regardless of whether sa residential, commercial o industrial areas ilalagay ang mga yan.
    Jan 2009
    #158
    We finally had a 30kW hybrid solar system set up. It's not yet fully commissioned and only about a third of the PV panels are currently online. It's now just pulling ~500W currently from the grid to supply almost 9kW of load.
    I hope all that budol wasn't for nothing.
Alternative Energy/Solar Power for Home Use [Merged]
