1. Full OEM mount replacement: Extremely high cost, merely copies the original design flaw and prone to repeated failure
2. Fault code masking: Only a temporary fix, will damage chassis ECU and interfere with drive mode adjustment long-term
3. Lumistag standalone upgraded sensor: Solves the root cause with reinforced structure to avoid recurrence, priced at $199
Each sensor is pre-calibrated to OEM precision standards, compatible with both left and right mounts. The left sensor can be replaced in situ without removing the transaxle mount, while the right only needs slight loosening of the oil cooler. Installation can be finished at general tuning shops, eliminating vibration, warning lights and PADM deactivation permanently with better durability than OEM parts. Lumistag
