Results 11 to 20 of 23
November 9th, 2005 09:38 AM #11
Hmmn, sabi dito long term storage so dapat pag tinabi hindi na gagalawin. How about filling the engine with oil up to the brim, disconnect the batteries, elevate the car, remove the tires para hindi mag-otso, have it greased sa ilalim, remove the high tension cables, spray pepper and salt (just in case bikolano ang rat ehehehe). Clean it, wax it and cover it.
November 9th, 2005 11:14 AM #12Originally Posted by jimaroquai
November 9th, 2005 01:25 PM #13Originally Posted by Hayward
Rat infestation is a serious thing with stored cars BTW. They chew up wires and hoses and can even get in as far as the a/c system in the dashboard... not that great.
November 9th, 2005 02:06 PM #14
six months? ok, first try to unhook the batteries. but have to change all the lubricants. if possible synthetic. lift your vehicle, to avoid strain on the suspension and tires as well. cover it with a good brant of car cover, but have it waxed (3 step exterior detailing).
sir, is this the dmax you're referring to? i'm not sure but the turbocharger might get rusty.
November 9th, 2005 02:23 PM #15Originally Posted by ian_rex
- Feb 2004
- 200
November 9th, 2005 10:16 PM #16mukhang malaki ang magagastos mo d2 at matrabaho -- storage maintenance, parts dis-assembly and assembly again when you come back.
why don't you endorse it to your trusted relative or friend to use it every once in a while. sabihin mo na lang "super ingat" and its their responsibility if something happen on it.
November 10th, 2005 10:07 AM #17
Looks like this is more complex than I thought it to be. aw man! hmmm...
Baka ma-extend pa sa 9 mons yun 6mons
November 10th, 2005 10:14 AM #18
Cardo... do you have a trusted relative / friend that can at least "exercise" your vehicles during your absence? The extended period is quite worrisome...
- Feb 2004
- 200
Tsikot Member Rank 5
- 3,144
November 11th, 2005 12:09 AM #20waaa? nothing mentioned about the explorer? sino gagamit while you're away or dala mo sya sa pupuntahan mo....
Monk-owned R53
