Results 11 to 20 of 20
January 1st, 2006 10:47 PM #11
Fluid in the intercooler hose is not a sure sign of turbo failure. It is only a symptom that must be supported by other findings/symptoms. Try driving a similar vehicle to compare if there is indeed a loss of power before spending tons of cash on a repair you may not actually need.
Without the turbo, your engine will only be making between 72-80 bhp as opposed to 99 bhp.
- Aug 2004
- 223
January 3rd, 2006 05:58 AM #13
Hi Guys,
Thanks for all the replies and advices. Just an update, I noticed last night that my space gear's turbo charger kicked-in, as in its like back to normal. The only thing I did to the engine was changing the v-belt that runs the alternator, coz nag twist na yung belt. I'm not sure if it's just a coincidence or it was the real reason for not kicking-in.
Could it be that becoz of the twisted belt, nagkaron ng loss of power kaya hindi nag kick yun turbo charger for the last 2 weeks? Does anyone has an answer to this mystery? lol
Now, the next thing to do is to get this turbo timer. Can it be easily installed? Can I install it by myself? if yes, is there anyone who has a workshop manual in installing a turbo timer?
Thanks again guys!
BANNED BANNED BANNED
- 3,790
January 3rd, 2006 06:09 AM #14kasama sa turbo timer ang installation wiring nito, you usually tap it sa ignition switch. It can be DIYed pede rin na yun store na bibilihan mo ang mag-iinstal nito.
- Sep 2005
- 110
January 3rd, 2006 04:35 PM #15Originally Posted by nugundam93
any contact # ng fusion r? how much kaya ang timer? or if walang timer how long should i idle my engine after using it?... thanks
- Jun 2004
- 476
January 3rd, 2006 10:10 PM #16Ang rule of time yata is to let your engine idle for a minute for every hour you run your rig relatively hard - turbo working/spooling most of the time. To be safe I let my turbo equipped rigs idle for at least a minute each time.
January 3rd, 2006 11:04 PM #17
pajojo: dunno the contact number for fusion R but you could pm AutoXer if he's here.
- Jan 2003
- 62
January 4th, 2006 10:53 AM #18Sirs,
How and when do you know the turbo kicks in? Is it like when I floor the gas and I feel the down shift? I have a 3dr Paj 2.5 diesel A/T.
Thanks
January 4th, 2006 11:19 AM #19Originally Posted by carnovice
- Jan 2003
- 62
January 4th, 2006 05:24 PM #20Oh, okay Thanks PajeroKid! Btw, is the black paj your ride? Galing e!
OT: Where can I get the clear signal/clearance lights? and cost na rin, thanks!
IIRC they're with AVID. The reported numbers in the TG article are from CAMPI.
Car Sales Data (2024)
