Results 1 to 10 of 20
December 29th, 2005 11:56 AM #1
Hi peeps,
I have Space Gear Delica (subic) 2.5L TDiC, 4d56 engine. Unfortunately, I think my turbo just died down 2 weeks ago . Any idea how much a surplus cost? and saan shop ok mag pagawa?
thanks!
December 29th, 2005 12:20 PM #2
Precision (located along Roces Ave. in Quezon City) repairs turbo chargers. You can dismantle your turbo (very easy DIY) and bring it there.
Another turbo specialist is the shop located in caloocan (9th avenue) but I forgot the name.
BANNED BANNED BANNED
- 3,790
December 30th, 2005 07:37 AM #4hindi ka siguro nag-ku-cool down after using your turbo ride...install ka ng turbo timer after you have it fixed.
December 30th, 2005 07:23 PM #5
Usually its a loss of power. What symptoms made you determine that the turbo went kaput?
You can also look into getting a surplus turbo but you'll need a mechanic to help you out on getting a good one.
December 30th, 2005 07:31 PM #6
Pasingit lang sirs,
Where can I get the turbo timer and how does itwork?
thanks.
December 30th, 2005 09:56 PM #7
turbo timer may makikita ka either as surplus sa banawe/evangelista, or new sa shops like fusion r.
it works by allowing your engine to still run for a preset time even after you take out the car keys so that the oil could still circulate to the turbo and cool it down.
- 3,790
December 31st, 2005 12:23 PM #8brand new may cost you P3000 to 4000 depending on brand. baka meron din cheaper than that.
January 1st, 2006 06:05 PM #9Originally Posted by vinj
According to a friend who owns a shop, one symptom is that when you pull off the hose from the Intercooler, may makikitang kang fluid at the tip of the hose. And meron nga sya nung binuksan ko. so my assumption is, deads na talaga sya.
Na-re repair pa ba sya? if yes, would you guys suggest a repair or bili na lang ako ng surplus?
thanks!
January 1st, 2006 06:06 PM #10Originally Posted by wildthing
yeah, most probably nga dahil dun kaya sya bumigay..
Did some independent research and decided to go with the white pearl crystal.... para maiba naman. ...
