Results 21 to 30 of 33
April 9th, 2007 04:17 PM #21
Wala naman major. Lumuluwag lang ang bearing while the engine gets old kaya umiingay. The silent shaft acts as counter weight to cancel the effects of vibration and noise. What i can suggest is check your belt baka tumalon ng ngipin thus rendering the shafts ineffective.
April 10th, 2007 04:14 PM #22
Sir 4JGtoosie,
Palagay ko ay sira na ang bearing dahil na-timing na ulit namin yung belt B. Pero ganoon pa rin. kailangan na sigurong bunutin at palitan ng bearing.
Thanks ulit
April 10th, 2007 11:34 PM #23
Ok,
Be sure marunong ang gagawa. May kailangan na special tool to pull out the bearing (malalim around 1/2 deep inside the block). Sa walco they sell the friction bearing at 250 per set. I suggest you do it before ka mag change oil.
April 11th, 2007 05:03 PM #25
April 11th, 2007 07:01 PM #27
April 12th, 2007 11:02 AM #28
kung properly adjusted na ang valve clearance niya, at may gano'n pa rin ang tunog, hard-starting ba? If in case na hard starting siya, baka may pundido kang glow plug, kasi pag hard starting tapos may tumunog na gano'n masyado malakas ang explosion sa silindro naiipon kasi ang diesel na 'di nasusunog kapag pundido ang glow plug..
April 12th, 2007 02:27 PM #29
HD,
Email you later.
Diesel will not ignite in any other form but mist injected to air under high compression and temperature. Even the glow plug cant ignite it without air and high pressure at a precise moment in the compression stage. Usually measured by degrees before top dead centerLast edited by 4JGtootsie; April 12th, 2007 at 02:40 PM.
April 13th, 2007 10:00 PM #30
4JGtootsie,
Nag-test ako, tinanggal ko ang timing belt B at pinaandar ko ang engine, nawala ang tak tak sound. Nagpalit kami ng bearing ng silent shaft pero naroon pa rin pagkatapos. Nextjob ay tatanggalin ko ang belt ng water pump pero nakakalagay ang timing belt B, baka sa water pump nanggagaling kasi nung nag test ako ay walang nakalagay na mga belt kundi timing belt A lang. Pinagtatanggal ko lahat ng belt, yung lang timing belt A ang natira.
sinabi moh! i hardly see my children now. when they were young, schedules were more predictable.
Traffic!
