Results 31 to 32 of 32
January 9th, 2004 02:19 AM #31
AC::: I will answer for otep and ubs73. Usually, you can find the glow plugs on the side of your engine just beside the injection nozzles (yun may tubings papunta ng injection pump) in your case, 4D56, sa right side if you're facing the engine, there is a strip that connects the tip of the plugs (positive side) together, then may wire na pumapasok sa harness.
Sa Isuzu parts sa Caloocan ang advice nila is to change all plugs when 1 goes bad.
Oil? kahit yun oil sa kamay ng mechnico mo pede ng ipahid sa dulo (yun umiinit na nakapasok sa makina) para umusok lang.
January 17th, 2004 11:44 AM #32
tnx po sir alfrasay... nakita ko na po.. but ang lalim.. dami nakaharang so pinagawa ko nalang sa iba hehe... i just hop... ok na ito the next time mag start ako ng malamig engine.. hehee... pinalitan ko na all 4.. but onli with replacements
Did some independent research and decided to go with the white pearl crystal.... para maiba naman. ...
