Results 1 to 6 of 6
September 10th, 2003 08:12 AM #1
kapag nalulubak po ako may parang umaalog sa right side ng suspension ko. I can feel it in the steering wheel eh. Normal kaya yun? Ok naman ang tightness ng steering ko and the last tiem na pina check ko, ok pa naman daw suspension ko. I just replaced my lower bushings.
...hindi kaya ball joints? 2 years na balljoints ko, di pa pinapalitan... :freak:
September 10th, 2003 10:44 AM #2
pa check mo din yung tie rod at rock end para sure ka ...sama mo na din ung shock...
FrankDrebin GuestSeptember 10th, 2003 01:26 PM #3
Ako naman sa L200, medyo mabilis yung takbo ko tapos bigla akong nalubak...biglan na lang parang gumewang-gewang ng sandali tapos nawala na lang.
Hindi ko alam kung ano yun?
September 10th, 2003 05:08 PM #4
Delta,
Kakapacheck ko palang nung mga tie rod ends ko eh. Ok pa naman daw. Yung shocks ko kapapalit ko lang this year. KYB. Kakailang kasi ung alog...
Frank,
L200 rin pala ride mo, meron na akong pagtatanungan ng mga L200 problems ko..hehe
September 11th, 2003 05:14 PM #5
baka wheel bearing? try mo itaas tapos try mo alugin yung gulong upwards and downwards.
September 27th, 2003 10:58 AM #6
sir djerms,
baka whee bearing bearing nga, i learned my lesson the hard way, sa SLEX pabalik manila, biglang nanginig din gewang gewang din, then itnakbo ko pa hanggang manila sana kasi nawala naman yung nginig pero pagdating dito sa near bicutan exit tumagilid yung gulong, na tow na ako.
ng i check ng mechanic, nabasg na ang caliper, disk brake etc, kung na check daw agad, bearing lang na 400 pesos, i ended up spending more than 12k, hope this helps.
Traffic!
