Results 1 to 10 of 23
November 2nd, 2002 11:26 PM #1
guys pki elaboreyt nman po ung kaibahan nito sa ibang 4wd. kc ang alam ko lang ay pde mg shift fr. 2h to 4h khit 100km/r ung speed mo. (tma po ba?) kc ung frontier ng pnsan ko kpag nka 4h ang bgal parang 50km/h lang top speed. tenks in advance mga diesel genius
November 4th, 2002 11:34 AM #2
lui,
Just a reminder: Never ever use the Frontier in 4wd on paved surfaces. Masisira ang 4wd niya kung walang 'slippage' ang surface. Saka na explanations kasi malapit na lunch ko. :mrgreen:
Yung SS4WD ng Pajero ay pwedeng i-shift from 2h to 4h at any speed under 100km/h. Gumagamit ito ng electronics at vacum para maging seamless ang shift from 2h to 4h. Mayroon din itong center differential para pwedeng gamitin on paved roads as a full time 4WD system.
But you still have to stop to lock the center diff or to shift to low range for serious off roading. Ang top speed ko ata sa lahar in 4L ay wala pang 80kph.
- 10,620
November 4th, 2002 05:54 PM #5
oic... tenk u po sir otep... nga pla pede na ba isabak ung stock na frontier sa mga off roading events nio? as in gulong pa lang napalitan pero same size at may cab pa.. gusto ko kc mnsan sumama sa mga events na ganun e kso bka ma stock lang ako... tenks po ulit
November 5th, 2002 11:45 AM #6
pajerokid,
4L yun. 5th gear. Ayoko na ulitin. Split second lang ako dun tapos bitaw na. Hehehe. Parang sasabog na makina.
lui,
Pwedeng pwede iyan. Mas mataas pa nga body clearance ng Frontier kaysa sa Pajero, eh.
November 5th, 2002 11:57 AM #8
fierari,
Ito naman kapag naka-on RWD pa din unless makadetect ng wheelslip saka pa lang mag-fe-feed ng power sa front axle. Sa Isuzu itong system na ito. Kaya doon sa indicator parang bar graph yung front wheels. Dumadami ang ilaw habang dumadami ang torque sa harap.
Pwede din ata siyang i-lock na naka-4wd.
- 9
November 5th, 2002 12:05 PM #10
Parang ganun na nga. Pero this one has can be locked in 4wd and has a low range setting.
And you can't opt out of the update.
National ID Law
