Results 41 to 50 of 52
August 9th, 2005 11:02 PM #41
Im Happy that things worked well with you, Too bad I cannot spare a single good word for ford for what happened to me! Happy motoring and drive safe bro.
- Jan 2006
- 55
January 25th, 2006 04:39 PM #42Originally Posted by S-works
My friend had a similar problem with his Toyota Forerunner. He had several bout of overheating and later, when he had the vehicle checked at one of the shop, they found a cracked in one of the cylinder head. One of the options recommended is to replace the entire assembly with "surplus" one, which they say would be a cheaper option. He called Toyota, and he was quoted for 39T just ffor one original single cylinder head.
Appreciate any recommendation from Tsikoteers, where to get surplus cylinder head assy for Toyota Forerunner.. thanks.
January 25th, 2006 04:54 PM #43
It should be replaced under warranty. A brand new vehicle shouldn't overheat no matter what.
January 25th, 2006 04:59 PM #44Originally Posted by niky
January 25th, 2006 05:12 PM #45
Unfortunately, if a driver uses a diesel engine in anger and doesn't care for it (i.e.:revs it like a gas engine all day long), it will wear down quickly.
Andami kong kilala na may negosyo na van rental, and they've had to overhaul lots of engines (mostly Nissan Urvan and Toyota HiAce Grandias) because of abuse.
July 27th, 2006 03:45 AM #46Originally Posted by niky
teka... hindi ba dapat mas matibay ang diesel engines compared to gas engines in the long run?
July 27th, 2006 05:37 AM #47teka... hindi ba dapat mas matibay ang diesel engines compared to gas engines in the long run?
July 27th, 2006 02:28 PM #48
Yup. The thing with diesels is, yes, they're much stronger, but at 4000rpm, there's more pressure on the cylinder head and walls than at 6000rpm in a gas engine. That's why diesel rentals break down so often.
Tsikot Member Rank 3
- Dec 2002
- 551
July 28th, 2006 09:18 PM #49s-works,
whats the update with your ranger ? is the engine still ok and whats the present mileage
July 29th, 2006 02:16 AM #50
onga..
naiintriga ako sa ranger..
so ung mga may problem ung ranger na made in the PI?
thank you its good naka timing chain pala. yan din concerns ko sa used car like sa dati kong...
